Best aftermarket clutch for a new H/C WS-6
Old 11-11-2007, 02:06 PM
Vrbas's Avatar
Default Best aftermarket clutch for a new H/C WS-6
I'm looking to upgrade my stock clutch (~70K on the clock)... where can i find a good setup?
It will be a DD cam and heads car and i would like to know what is the best clutch and flywheel to go with. I'm looking for a kit that has everything i need that will run me ~$400 ---> under that would be optimal if possible. Thanks for your time.
***direct links are more than welcome
Old 11-11-2007, 02:09 PM
1_bad_TA's Avatar
Center force dual friction or a SPEC clutch.
http://www.lmperformance.com/c/2/1.html#Clutch%20Kits
Old 11-11-2007, 02:12 PM
RamjamWS6's Avatar
Ive heard nothing but bad things about the Centerforce.........and the SPEC is pretty hit or miss...
I went with the Ram HD....so far have no problems.....chatters a little bit but nothing to bad .....i use the car as a DD too....
Old 11-11-2007, 02:14 PM
1_bad_TA's Avatar
I never heard anything bad about either myself. Check out the link I posted. I believe they are a sponsor here too.
Old 11-11-2007, 02:16 PM
RamjamWS6's Avatar
If you've never heard anything bad about spec just search on this forum........some people have them...love them with no problems.....others put 2500 miles on it and it slips and goes crazy.....springs are prone to falling out as well
Old 11-11-2007, 05:39 PM
RareBreed0295's Avatar
If i was you, id look at the Ls7 clutch package from spdc. They offer the whole kit for like $389. Just a thought.
Old 11-11-2007, 05:50 PM
1_bad_TA's Avatar
Did a search like ya said, didn't think they were that bad untill I seen some of the pics.
Old 11-11-2007, 06:03 PM
chewy99ws6's Avatar
+1 on the Dual friction, that is what I use and I love it.
I had a spec 3 and didn't really like it.
Old 11-11-2007, 07:28 PM
bad6as's Avatar
i went with a ls7, its nice but it wont take 6K dumps on slicks but if your not doing that its great.
i spent 500 or so for teh clutch and flywheel and master and slave. i would save for a texridila if i where to do it againb
Old 11-12-2007, 09:25 PM
Vrbas's Avatar
So far it looks like LS7 is my best bet.
Any other opinions?
Also, on average how much would a local exhaust shop charge for a clutch install?
Old 11-13-2007, 02:18 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I think the LS7 kit will fit your needs. It held behind my H/C/I/150shot CETA
Old 11-15-2007, 11:29 PM
flyin ryan's Avatar
My buddy and I both have Centerforce dual friction in our cars and no problems what so ever .
Mine has over 40 k on it and sees 7-8 trips to the track per year on Nittos.
In addition, I installed a Centerforce DFX in another car a few months ago, (over 500 hp) to the rear wheels and other than a slight chatter , which is to be expected, he is very happy with it.
Ryan
Old 11-16-2007, 10:00 PM
00T\A's Avatar
Do the LS7 you will love it on the street.
I hear is dosen't do to bad at the track either with some dr's are et's.
Old 11-18-2007, 08:27 PM
Vrbas's Avatar
Well for the record it's going to be seeing 98% street. Thanks for all the input.
Old 11-18-2007, 08:36 PM
01FbTaWs6's Avatar
save and get a textrilla. You wont be disappoined.
Old 11-19-2007, 02:09 PM
theguyulove2hate's Avatar
i bought my 99 Z28 with a spec stage 1. It was nice whill i had it, it blew out with in 5 months of me owning the car. Then i went out and go a spec stage 3 it lasted all of 6 months. Now i have a centerforce and i love it. It holds everything i can throw at it and takes it all, the counter weights make it really nice to drive. Dont get specs there a waste of money.
Old 11-20-2007, 01:50 PM
silverbeast's Avatar
Stay away from Spec!! They are junk and dont stand behind their product. They will ALWAYS blame it on a bad install.
Old 11-20-2007, 03:01 PM
00Hawk437's Avatar
I went with an Ls7 clutch and a slightly used Ls2 flywheel. I use my ride mostly on streets, but I've also taken it to the track and it behaves flawlessly....
Old 11-20-2007, 03:23 PM
ConfusedGarage's Avatar
The more I beat on my textralia at the track the better it feels. 100 degree day, 20 hotlaps? No sweat. I love this thing, and the only issue is low engagement point that you have to work around.
Old 11-21-2007, 03:41 AM
di0ck's Avatar
Ah, that's what I hate! But checking their website, it say they retain "near stock pedal travel". What gives? Sounds like a great clutch, do you drive it daliy?
