N2RACINGLS1's
11-11-2007, 07:35 PM
1998 LS1 with 91,000 miles on it runs very good made 330 HP and 350 ft lbs of TQ to the rear wheels with just long tube headers, Complete engine except for the following starter, alt, pulleys, throttle body, coil packs, motor mounts, and wire harness. $1,700.00 has had some dry NOS used on it. 75HP shot was the max.
1998 F-body 4 speed auto transmission used for 90,500 miles, stock convertor, factory trans pan and B&M chrome deep pan and transmission cross member. $275.00
1998 F-body Alum drive shaft with almost new front U-joint and rear U-joint for 9-inch rear. $150.00
1998 F-body 3 channel 3.23 rearend complete except for brake rotors and pads. Still has the backing plates. $300.00
1998 Stock rear lower control arms, torque arm and panhard bar $100.00
1998 LS1 F-body metal gas tank with working fuel pump $100.00
4 1998 16" Pontiac silver factory twisty not chrome some scuffs on the rims with Goodyear GSC's with 70% tead life $200.00 will not remove tires from wheels or break up set.
B&M Hammer Shifter with cable and 6 speed console for Firebird or T/A in grey color. Can be used for 4 speed auto or turbo 350 / 400 swap. The shifter hs backup light and neutral safety switches. $225.00
V-8 K-member for 1998 - 2002 F-body complete with upper and lower control arms, engine stands, brake set up for Weld Pro Star Wheels and the ABS controller rotors and pads have about 1,000 miles of use on them. No steering rack. $350.00
1998 V-8 front shocks and springs including spring perch on top $100.00. The spring perch aftermarket is $60 each.
Brand new Fuddle HP 3,800 stall and 2.4 STR convertor for Turbo 350 / 400 swap to LS1 crank and flexplate. $350.00. This was a $600.00 convertor
If someone wants to change an LT1 car to LS1 or a V-6 F-body to a V-8 here is your chance!! I live in close driving distance to Knoxville, Crossville, Cleveland, Morristown, Maryville. All items would be for local pickup only.
Thanks for looking!!
