FI valve/spring question
I started a thread a while ago about my allpro heads. Now I have a little more $$$ to buy the valves and springs to get this thing rolling. Bob from allpro gave me a idea of price and needs info for the valves. He said he needs to know spring dia., coil bind pressure, and installed spring height and spring poundage. I'm a newb when it comes to valvetrain so, help me out guys. Is there a standard valve length?
Heads already have seats installed and cut along with guides. Valve sizes are 2.05 and 1.60". Stock rockers will be used and I don't have push rods yet. Cam is a 236/236 .587/.587
thanks in advance guys !
Eddie
Eddie
I am:
Allpro heads + ETP valve springs.
Wouldnt it make more sense to let the head builder/supplier, spec and supply everything and assemble them ?
I also have a choice between ti and hollow stainless for the intake valves. Ti is twice as expensive as ss.
I would think a set of patriot duals would work, just buy the kit, they come with spring cups and everything, you can machine the heads if need be to acheive proper spring height. Not sure on the valves, wish I knew, I've never run allpros. =\
