LS1-Edit - what are these tables?
Old 06-18-2003, 10:26 AM
ElanMike's Avatar
Default LS1-Edit - what are these tables?
I have a LS1 edit program from Cartek and the following tables are edited. What are these tables?
Engine - Idle+limiters - IAC Park Posn
Engine - Ignition - High octane spark advance
Engine - Ignition - Low octane spark advance
Engine - Ignition - Base spark in drive
Engine - Ignition - Base spark in park
Engine - Ignition - TCS retard vs RPM - all set to 0?
Engine - Ignition - Torque reduction - all set to 0?
Diagnostic - Test parameters - DTC1514 calc airflow
Appreciate the feedback.
Thanks!
Old 06-20-2003, 04:14 PM
Progas's Avatar
Default Re: LS1-Edit - what are these tables?
Noticed your location is CA, With your setup are you within CA emissions?
Old 06-23-2003, 10:28 AM
ElanMike's Avatar
Once i get the car tuned in properly, I'm going for a pre-smog test. From what i've been told, i should be within CA emmissions. If not, I'll need to get some clever tuning to get me through.
