Gauge panel install questions
I'm wanting to hook up a 98 F-body instrument panel in my 92 Mustang. I have a Speartech harness with the VSS,Tach, Water temp and Oil pres. signal wires pulled out of the PCM. Beside those 4 wires, can anyone tell me what else needs to be connected (pin #)to the instrument panel to get the gauges to work correctly?
BTW, it is a 98 harness and PCM.
here's the pinout:
Pin
Wire Color
Circuit No.
Function
A1
PNK
39
Power feed from gages Fuse 9
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
SECURITY indicator lamp control
A4
BRN/WHT
419
SERVICE ENGINE SOON indicator lamp control
A5
PNK
39
A6
YEL/BLK
68
Low coolant level indicator control
A7
BRN
358
AIR BAG indicator control
A8
PPL/WHT
1572
TCS OFF indicator control (with NW9)
A10
TAN/WHT
33
BRAKE warning indicator lamp control
A11
LT GRN
11
High beam headlights on
A12
PPL/WHT
237
FASTEN SEATBELT indicator lamp control
A13
ORN
640
Power feed from PWR ACCY Fuse 7
A14
RED
225
Generator output indicator control
A15
BRN/WHT
1173
Oil level lamp signal
A16
DK BLU
1537
LOW TRAC indicator lamp control
A17
DK GRN
135
Coolant temperature sensor signal
B1
BRN
9
Odometer illumination
B2
GRY
8
IP illumination lamps feed
B3
BLK
650
Ground
B4
WHT
375
SKIP SHIFT indicator lamp control (V8 only)
B5
DK BLU/WHT
1415
Right turn signal switch output
B12
DK GRN/WHT
817
Vehicle speed signal-4000 pulses per mile
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
Left turn signal switch output
B15
BLK/WHT
451
Ground
B16
TAN
31
Oil pressure indicator control
B17
LT GRN
867
ABS fail signal
Pin
Wire Color
Circuit No.
Function
A1
PNK
39
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
A4
BRN/WHT
419
A5
PNK
39
A6
YEL/BLK
68
A7
BRN
358
A8
PPL/WHT
1572
A10
TAN/WHT
33
A11
LT GRN
11
A12
PPL/WHT
237
A13
ORN
640
A14
RED
225
A15
BRN/WHT
1173
A16
DK BLU
1537
A17
DK GRN
135
B1
BRN
9
B2
GRY
8
B3
BLK
650
Ground
B4
WHT
375
B5
DK BLU/WHT
1415
B12
DK GRN/WHT
817
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
B15
BLK/WHT
451
Ground
B16
TAN
31
B17
LT GRN
867
ABS fail signal
