Nitrous Oxide - Zex Direct Port & Fast Intake
View Full Version : Zex Direct Port & Fast Intake
Roy V.
11-13-2007, 11:22 AM
I've done a search and didn't come up with a lot of detail so here it goes:
Is anybody here running the Zex direct port kit that plugs into the FAST manifold and how do you like it?
I realize that the advertised figures are most likely crank #s as opposed to rear wheel so that's a matter of jetting up a bit which is no issue.
Any comments would be appreciated.
Thanks,
Roy
Chris@NitroDaves
11-13-2007, 11:30 AM
I dont have it nor run it but we have plumbed some on the Fast intakes.
http://www.nitrousoutlet.com/installs/install.asp?id=13
-Chris
Roy V.
11-13-2007, 11:34 AM
-Chris
Thanks for the response and the link Chris, much appreciated.
Nitro Dave's Nitrous Outlet
11-13-2007, 03:55 PM
I would like to see one on a car. We have plumbed them ans sent them out but never seen one mounted. My concern is that with those long hoses it will look conjested and cluttered. The system comes with the premade hoses. You just drill and tap the intake and bolt it together. You are using a large nozzle so make sure you get the angle correct so the body of the nozzle does not jam on the base of the intake while tighting it in.
Dave
Slvr00Bird
11-13-2007, 04:03 PM
Does anyone have pictures of the Nitrous Outlet kit with the hidden halo spray bar installed? I was just wondering how well it was hidden and what exactly they meant by "protrudes through the air filter"...
here's the link
http://www.nitrousoutlet.com/catalog/product_details.asp?group=15&model=42&dept=11&product_id=1205
11-13-2007, 05:23 PM
Shoot Chris@NitroDaves a pm. He can email you some pics. The hose comes up through the air filter to supply the spray bar the nitrous. The solenoid mounts under the airbox.
Dave
Slvr00Bird
11-13-2007, 05:25 PM
Alright thanks buddy
11-13-2007, 05:27 PM
No problem
