lt1 to ls1 battery hookup questions
Ok where do I need all the wires to go to? One goes from the battery to the distribution block for sure. Do I need a wire going from the battery to the starter? What size of wire do I hook the alternator up with? Thanks in advance guys!
Ok so the 3 wires coming off my positive cable should go to dist block/starter/alternator. Thats it? And the ground should ground on the block and the frame correct? Thanks for your help!
