how much for a rearend
Old 11-14-2007, 07:00 PM
jpfaut01's Avatar
Default how much for a rearend
so i just picked up a 93 z28 to play around with and the first thing on my list of stuff that needs to be fixed is the rear diff. can anyone give me a ballpark estimate on how much i need to save to have someone rebuild it. i'm going to keep it totally stock so please no info on swaps.
Old 11-14-2007, 10:55 PM
whyte95ZRida's Avatar
You looking to include a good set of new gears? If so I'd say probably somewhere around a total of about 400-600(gears, bearings, seals, fluid, and install). Thats going with aftermarket gears...gm gears will be over that much alone.
Old 11-15-2007, 11:31 AM
jpfaut01's Avatar
i guess i won't know what i need until i have it opened up, but at any rate i need to start saving for the worst case scenerio
Old 11-15-2007, 01:13 PM
Internet Mechanic
BlackScreaminMachine's Avatar
if you do a rear gear swap, I wouldnt expect to walk away less then 500$, if it invovles a diff swap add that to the price.
Most times your 1/3 to 1/2 way to the price of a 12 bolt.
