Need crotch strap mounting advice
I'm looking over my mounting instructions for my 5 point harnesses and I see that the anchor bracket mounting needs to be as close to 0* as possable, it specificly shows that mounting it flat to the floor wont work because of the 90* angle that it would create. What did some of you do to avoid this ?
TIA
Hummer
TIA
Hummer
I welded a tube across the seat mount. Then I attached the crotch strap to that with a wrap around bracket.
Wolfe 6 point rollbar
http://www.wolferacecraft.com/Search...?CategoryID=20
