What shock and spring combo do you guys recommend???
have a 02 SS M6 heads/cam/nitrous... sees track but is also driven alot on the road.
what kind of shock and spring setup are yall running that yall have had good success with?
I would use a strange double adjustable in the front so you can tune the compression and rebound, so you can have a 90/10 shock to drag race, a 40/50 for street driving and 80/70 if you ever want to road race, those are just examples of rates but you get the point.
In the rear a strange or qa1 single adjustable rear shock will work fine for all of the above applications.
For drag racing only I run a 275 front /150 rear spring, but since it is your street car i would maybe try a little stiffer rate, like a 300 front and a 160-175 in the rear. It will handle a little better than the softer springs.
Stiffer the spring the better the street driving will be and towards the softer side is more for drag racing.
I take it most guys are running the 275-300 lb springs..but what length springs are you running?
I've read a few places about a longer, softer spring to hold more energy. I have a feeling you could get the suspension all outta wack with too soft a spring, thats too long, and the shock is put into overload while driving?
