Anyone have a SFI flywheel break/twist apart?
Like at teh center hub thats bolted to the crank, still there bolted and loctited fine, but the wheel and start ring just spins around that because it looks like someone cut a circle around the bolt pattern
Anyone ever seen anything like that? Not a stocker, this is an SFI approved steel plate
Heard of it happening but never seen it, I bought a good one in hope of not having to.
Buy one of the thicker ones, some are thicker than others and have a lot more material, which will take a little power away but will help launch the car harder.
Most are .187 thick, there is one I saw before called "the Wheel" that I think was even heavier and thicker. Like 5 pounds over stock or something.
I assume the one that cracked is just the stock style SFI one, those are just copies of the OE flexplate made of thicker steel and have the ring gear welded on 360*. They tend to crack where they are stamped in the center to get the offset since thats the weakest spot.
If you broke something like a TCI most likely something is out alignment. If you are using a JW bell it will hit the rear cover bolts and the trans will not be flush with the back of the engine and will crack the flexplate. Same thing if you converter is ballooning badly, it tries to push the flexplate forward, either the converter will bottom in the crank and take out the thrust bearing or it will push the flexplate forward, after doing that a few hundred times things get a little weak.
All you can do is doublecheck everything and make sure its right, if it is try a different manufacture.
WMSuperSport, The JW bellhousing we are using is made for a Gen1 SBC thats why they don't clear. Some tranny shops like Rossler will clearance them for you for a fee.
