what octane gas?
The computer quickly detunes the engine if knock is detected, preventing damage. So 87 or even substandard fuels will run the engine. Just don't expect to get the best mileage or peak power.
Minimum 91 gives the best performance overall and is the design standard.
For everyone that likes to run higher than 91 if your car doesn't knock and doesn't pull any timming then 91 is the way to go. You car will make the most power at the point right before it knockes because it is able to use all the fuel..
LS1Tech Administrator
Received 1,483 Likes
I use 116 in all my stock cars for best power. When I want good MPG, I just switch them over to diesel. I've been doing this for about 10 years, it works great.
(wow I hope nobody actually takes that seriously!)
The majority of Oklahoma is 91. There are a few places where you can get 93, but they are few and far between. I run 91 in the Camaro and 89 in the daily driver. I spent some time in New Mexico, they had gas as low as 84 I believe. I was flabbergasted, had to resort to some Toluene ghetto-octane-boost to make it though. As for the fbodies, you can run 91 no problems. When you start changing the compression ratio, or adding boost you'll need a higher octane rating.
I used to only work with old carb motors, i only just got into the LS1 game. so anything new i can learn is a step in the right direction.
