kicker/powerbass combo
Old 11-15-2007, 08:22 PM
dutinsss's Avatar
Default kicker/powerbass combo
hey guys, i dont know a whole heck of a lot about sound systems, just the basics. i want to run two kicker cvr 10's or the same size fosgate P2, now do i need the 2 ohm, or the 4 ohm subs? i want to hook them up to a hifonics ZXi1006, 1000 watt 2-channel A/B class amp. all i need is a two channel because i'm only running two subs, right? thanks a lot. and if this wont even work, let me know lol.
Old 11-15-2007, 11:51 PM
bmnicolosi's Avatar
get a class d mono block, better for subs. if the amp is 1 ohm stable get the dual 4 ohm woofers so the amp sees a total of 1 ohm, if the amp is 2 ohm stable get the dual 2 ohm woofers so the amp will see a total of 2 ohms.
Old 11-16-2007, 08:52 AM
dutinsss's Avatar
wont a monoblock amp only power 1 sub?
Old 11-16-2007, 01:32 PM
KEE AUDIO's Avatar
Depending on how stable the amp is you can run multiple subs off a monoblock. A monoblock amp is 1 channel but you can run as many as 4 or more subs in some cases from one amp as long as the subs and amp are the right wattage and impedance. Some amps are stable down to .5 ohm. Here's a wiring diagram that may help you some:
http://www.crutchfield.com/learningc...ng.html?subs=2
Old 11-16-2007, 04:48 PM
dutinsss's Avatar
so which is better? running two subs off of a monoblock, or a two channel amp? and would a 1000 watt two channel Hifonics Zeus A/B class amp be a good choice to run two kicker CVR 10's? and thanks for that diagram, it helped a lot.
Old 11-16-2007, 07:43 PM
streetassasin's Avatar
you can always buy the system I have for sale
2 kicker cvr 12''s and a kicker kx1200.1 for $400
Old 11-16-2007, 08:00 PM
dutinsss's Avatar
how old are they and what kind of condition are they in? if you can get me some pics, we might be able to work something out
Old 11-16-2007, 08:19 PM
dutinsss's Avatar
nevermind, i just found the pics. i'll let you know if i can buy them from ya though
Old 11-17-2007, 09:06 AM
cool lmk If you want em, Im about to get some new pix up
