How to remove IAT sensor to install SLP lid
Got my stock intake off. Need to transfer the sensor/gromet over the new lid. Its so close to the corner...it is hard to turn. Does it unscrew or do I have to pull it out? Tried to grab it with a needle nose and cracked it. any advice before I totaly screw it up?
Location: The dirty taint of the country. ...Los Angeles
Get some pliers on the inside of it and compress it a bit so you can sqeeze it through. Once you've got enough of it through, push it with your thumb from the inside while your turning it with our other hand on the outside.
I think the designer that put the iat in that place should be shot. He must have been smoking crack. I had to completly destroy the iat to get the gromet out. But I appreciate the quick responses.
