Truck Manifold Twin Turbo New #'s
Old 11-15-2007, 11:49 PM
HUNTER02SS's Avatar
Default Truck Manifold Twin Turbo New #'s
I switched to some AFR head's and so far at 18#'s of boost,
I am at 1089rwhp and 1056rwtq. The plug's are shot,so new one's go in tommorow and going back to due some finishing touch's!
Old 11-16-2007, 12:02 AM
MonkeyBoneSS's Avatar
Nice numbers!!! Have a graph I 'm sure. Would like to see it, also what did you tune it with (program)?
Old 11-16-2007, 01:03 AM
ls1king000's Avatar
Nice numbers, I would think those turbos are almost maxed out. How high do you spin the rpms?
Old 11-16-2007, 08:09 AM
HUNTER02SS's Avatar
Spinning the motor to 6800rpm. I would also think the turbo's are close to be maxed out also?
Old 11-16-2007, 08:58 AM
KraZy's Avatar
Thats a huge increase congrats man!
What are you doing for fuel for the beast?
Old 11-16-2007, 09:13 AM
HUNTER02SS's Avatar
Actually there is a few change's other than just the head's. The dart's had a 62cc chamber so we could not get to aggressive with the tune and I was using 104 unleaded fuel(GT Plus),because it would push water,but the afr's have a 75cc chamber and the thicker deck and I also switched to 114 leaded fuel!So far no water pushing and I just took out the plug's and other than being fouled they look fine!
Old 11-16-2007, 10:46 AM
Camaro01SS4life's Avatar
Sweet #'s...I saw your vid against the TT stang...I bet that thing is a beast...Time to update your sig numbers
Kev
Old 11-16-2007, 10:58 AM
kp
kp's Avatar
Congrats again, I would think the turbos are getting close to the end but you still may find a few more HP there.
Old 11-16-2007, 11:04 AM
LS1Tech Sponsor
Superman09's Avatar
amazing numbers! Where is such vid vs a stang.... i want to see this beast in action!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-16-2007, 11:07 AM
HUNTER02SS's Avatar
Go to youtube and do a search on a ttss camaro and I think it is one of the first one's that pop up!
Old 11-16-2007, 11:12 AM
MECHAM's Avatar
for the lazy's
http://www.youtube.com/watch?v=SEmlCG_GmJA
Old 11-16-2007, 11:32 AM
LS1Tech Sponsor
Superman09's Avatar
awesome vid! What happened to the Cobra?
__________________
Old 11-16-2007, 12:33 PM
Tiago's Avatar
very nice numbers!
congrats
Old 11-16-2007, 01:28 PM
HUNTER02SS's Avatar
The cobra 's tread came off at the end of the run. he was running the cheap pep boy skinni'es.
Old 11-16-2007, 02:02 PM
CHRISPY's Avatar
Do you have pics of the setup (larger ones than your avatar?)
Old 11-16-2007, 05:48 PM
frcefed98's Avatar
Outrageous!!
Old 11-16-2007, 06:04 PM
venom ws7's Avatar
WOW man huge congrats on the new Numbers.
Those AFR Heads are freakin great.
What is the CR of the engine now??? Swaping from 62cc to 75cc heads had to lower the CR a littel Right?????
Did change the M6 to powerglide??? I remember you were thinking about it.
Again Congrats.
Old 11-16-2007, 06:41 PM
gnx7's Avatar
What cam are you running? Great numbers.
Also is this stock PCM? What size injectors?
Old 11-16-2007, 06:56 PM
HUNTER02SS's Avatar
I still have the 6 speed. The compression dropped,just not sure how much.
Old 11-16-2007, 07:10 PM
venom ws7's Avatar
That even more great the Compression dropped and still made alot more HP and TQ.
How much Timing did you guys add???
Are you still with 3.23 gears 10bolt???
Sorry for all the questions.
Quick Reply: Truck Manifold Twin Turbo New #'s
