M6 -> A4 & A4 -> M6
Old 11-16-2007, 11:26 AM
PatrickF's Avatar
Default M6 -> A4 & A4 -> M6
I have a 98 Z28 A4. A friend has a 2000 WS6 M6. He wants my built auto and I want the six speed.
From my reading the T56 will drop right into mine little sweat, just need to solder some wires and put a 6 speed tune in it.
I can't find much on what is needed to put my A4 in his M6 car.
Old 11-16-2007, 03:43 PM
firechicken_98's Avatar
Read the sticky at the top.
Old 11-17-2007, 11:38 AM
PatrickF's Avatar
I've been digging through it but can't find much on the M6 -> A4 half.
Old 11-17-2007, 07:48 PM
8a8mfh's Avatar
Speartech (a sponsor) has the wiring harness you need.
Old 11-20-2007, 06:01 PM
PatrickF's Avatar
Is there anyway to go from M6 to A4 without buying/swapping an entire harness?
Old 11-22-2007, 05:56 PM
jmm98LS1's Avatar
The 4l60e is an electronically controlled transmission, so unless you convert to a manual valvebody, your options are to find/buy a harness to connect it to the factory pcm or buy a standalone controller to run the transmission. Cheapest way to do it is a wiring harness.
