Suspension & Brakes - BMR XTREME Rear Anti-Roll Bar worth it?
WS6TransAm01
11-16-2007, 02:08 PM
If I already have a Suspension Techniques 25mm solid sway bar with polyurethane bushings and the car does launch strait, with the front wheels an equal distance from the ground wile in the air, is it worth anything in added traction, better 60' and ET to switch to the BMW Anti roll bar or any similar bar?
Also, along the same lines, if I already have BMR tubular, non-adjustable LCA's with polyurethane bushings, is it worth swapping to solid mount, adjustable LCA's?
Thanks guys!
BMR Suspension
11-19-2007, 11:12 AM
If the car is already tracking straight you probably are not see much of a gain.
Lee Spicher
leespicher@yahoo.com
(813)986-9302
black01_WS6
11-19-2007, 12:32 PM
I need one of these badly. I am going with the jug soon, and i already have problems. They are a bit pricy, but worth it if it works.
tomz28
11-20-2007, 02:41 AM
i have a pro-series shopn sway-bar and the thing is over kill and a half if it is going good stay with what you have and maybe air bags if you need to up grade but thats just me
black01_WS6
11-20-2007, 06:50 AM
Well this unit is used mostly for the track. Since I don't DD my TA I will be able to bear it. I already don't have a front sway bar.
