12 Second Club - 12.02 @ 110, Stock internals 3500lbs+ raceweight
01_ram-air
11-16-2007, 07:00 PM
Finally got to the track during some nice weather.
1.58 60' :D
7.59 1/8
88 mph
12.02 1/4
110.79 mph
I had just installed the BMR Xtreme Sway bar and the motor pass felt strong on the launch. It was time to put it to the test and spray a 150 shot out of the hole. Launched, hooked, and BOOM....there went the 10 bolt. :bang: No worries, I had put that 10 bolt through a lot over the past couple years. A couple 1.49s and many many 1.52-1.54 60' times. I'm hoping to push her in to the 11s N/A and 10s on teh jug.
HaulinHawk
11-16-2007, 07:04 PM
Damn nice time on just bolt-ons!!!Put a cam in that biotch,run low 11's n/a and then spay it too the mid-low 10's!!!!!Congrats!!!!!:chug:
RamAir02TA77
11-18-2007, 10:25 AM
That sucks about your 10 bolt im hoping mine will hold up for alittle while so I can test out my 4l80e. I have pulled a best of 1.46 on mine and numerous 1.5x spraying it right outta the hole. I do have a spare 3.42 10 bolt that I got out of a v-6 car at the junkyard for 30 bucks that I would probably throw in.
01_ram-air
11-21-2007, 12:07 PM
Yeah, it's one of those things that you expect but hope don't happen. I guess my luck finally ran out.
Tommyv8
11-21-2007, 03:50 PM
I'll probably eventually stall and spray mine, hopefully the 2.73s will keep the rear together; I really don't wanna have to shell out the $$$ for a 12 bolt or 9 inch.
Nice runs!
01_ram-air
11-23-2007, 04:37 PM
Nice runs!
If you add enough power and combine it with a tire/track that hooks, you'll eventually need to upgrade the rear. But give her hell till she breaks, that's what I did. :D
Heat Treat Pete
12-02-2007, 09:11 PM
great times, your car runs awsome. What size gear are you going to?
01_ram-air
12-02-2007, 09:39 PM
Thanks. More then likely 3.73s
DarkJuggalo
12-03-2007, 03:32 AM
nice pass =) sucks about the breaking rear though =(
Black FormulaLs1
12-03-2007, 04:50 AM
have broken 3 rear's...save up your money and buy something beefy...you will only be pissing your money away otherwise
01_ram-air
12-03-2007, 09:18 PM
Yes sir. That's exactly what I'm doing. I'll more then likely put a 9" in her. The car will be sitting in the garage for the next few months until I can afford the rear end that I want. And then I'll start saving for a new tranny as I figrure that'll be the next thing to go.
ApexVIII
12-04-2007, 12:15 AM
to bad about the rear end but nice times!
Bitemark46
12-04-2007, 12:23 PM
Sucks to hear Jarrod. Nice times. Feels good to run a good ET with no power isn't it?
-Mark
MemphisZ28
12-04-2007, 01:50 PM
Someone posted they got a v6 rearend out of a junkyard for 30 theyd throw in.. is it just me or wuold you be 1 legged man in an ass kicking contest with no posi?? BTW how did the stock limited slip hold up? still spinning two tires after all those fast passes before you broke the rearend
rjc1629
12-05-2007, 12:30 PM
The Y87 (I think thats the number) option came with rear disks, 3.42's and posi.
CamaroRacing12
12-05-2007, 02:03 PM
thats interesting....
btw nice times
Nimitz87
12-05-2007, 02:05 PM
do you want a stock 10 bolt cheap? or anything to trade lsx related?...has 34k miles on it 2 1/8 mile passes on street tires.
I'll be up there around christmas time.
Chad
mullenh
12-05-2007, 08:45 PM
Man your avatar is a picture of my dog! 2nd boxer I have had.
green28
12-05-2007, 11:20 PM
Sorry about the rear end, but nice times for SI at that weight. What are your mods?
RAGENZ28
12-05-2007, 11:58 PM
1.58 60' :D
7.59 1/8
88 mph
12.02 1/4
110.79 mph
How about 9's on the jug :)
exit
12-06-2007, 10:48 AM
your bolt ons only?
or do you have cam? heads?
you trapped the same speed as me but much better 60
slowmofo
12-06-2007, 01:28 PM
nice times, what gear and stall are you running?
your 60' is insane for full weight. I only went 1.69 with my little 3k stall on motor
hoping for something closer to mid 1.6's with the yank 3600
01_ram-air
12-07-2007, 10:47 PM
Chad
I'm just going to save my money at this point and put a 9" rear in the car. No money wasted on another 10 bolt. Thanks for the offer though.
-Mark
Thanks Mark. Gotta love a nice 60' :D
That's my boy. He's 70lbs and about to turn 1.5 years old on the 19th. I also have a 7lb yorkie who rules the boxer.
Not much. lol Lid, QTP headers, TDs dumped, 4000 stall converter, a little bit of suspension work (lcas, relo brackets, sway bar), and a tune.
Not going to happen with stock internals, stock tranny, etc. But, in due time I hope to run in the 9s.
your bolt ons only?
Yep, bolt ons only, and not all of them. could still due underdrive pulley, electric water pump, etc.
3.42s, ST Yank 4000.....they don't make the ST version anymore. It's an N/A converter, but I've sprayed the piss out of it. Oh, and I bought it used out of a 10 sec car that use to spray the piss out of it too. It's definitely a loose converter.
Zero4488
12-09-2007, 01:07 PM
sick times...can't wait to get my car to the track...
