I'm getting an MS4 cam, which intake should I get with it?
Old 11-17-2007, 09:55 AM
CALL911's Avatar
Default I'm getting an MS4 cam, which intake should I get with it?
I've decided on the MS4 cam for my Formula in my sig. Which intake should I get for it? I can get an LS6 intake, and have it ported for a lot less than a FAST 90, but will that starve me of some power? Or is the little power possibly gained by going with a FAST over a ported LS6 not worth the money?
Old 11-17-2007, 10:09 AM
5.3LJimmy's Avatar
The LS6 intake will do well, but the FAST would be an improvement. If you can get your hands on an LS6 cheap go for it. Personally I would put money towards a set of heads before considering the FAST intake. Some good flowing heads will increase power output about 3 times more than the intake. I would save the FAST for the last mod you do, unless you are trying to run a max effort cam only setup.
Old 11-17-2007, 12:56 PM
CALL911's Avatar
I was wondering how much power extra is the FAST really going to yeild me over a ported LS6 intake. The difference in price is about $600.
Old 11-17-2007, 05:13 PM
5.3LJimmy's Avatar
probably 10-15hp.
Old 11-18-2007, 11:07 PM
Reject's Avatar
just get the fast if your looking for every single last hp possible.....then get heads. lol as heads will now be your biggest restriction
Old 11-19-2007, 12:34 AM
CALL911's Avatar
Yeah, but the delimma is for a little more than the difference in price from the LS6 intake to a FAST, I could have myself a set of heads. And the heads would make a LOT more difference than an LS6 intake to a FAST would. I have a certain power level I want to attain (along with a budget) and I guess I can't really justify spending that much more for a FAST when the gains would be minimal over a ported LS6.
Old 11-19-2007, 02:31 AM
LS1>girlfriend's Avatar
get the ls6 intake, get some heads then do the fast 90 if you think you need it.
Old 11-19-2007, 03:19 AM
stevensLS1's Avatar
alot of guys dont go with the fast intake. go read around the forced induction area and see why. patrick g just made a thread and has alot of good info. ill link it here.
https://ls1tech.com/forums/forced-induction/815286-best-intake-manifold-turbo-kit.html
Old 11-19-2007, 10:43 AM
CALL911's Avatar
https://ls1tech.com/forums/showthread.php?t=815286
Yeah, I was already aware of this info. It won't apply to my application though as my Formula will be staying N/A.
