73 Camaro swap
73 Camaro swap
This wouldn't be the normal LS1 swap. I want to take a donor 98-02 F bod and swap drivetrain, interior i.e. dash, seats, center console, as much stuff as I can. Would even like to get the delay wiper swapped over.
Is there a way to get the ABS to work with on the old car? The rearend would be easy, but how about sensors on the front? I will probably use the entire wire harness from the donor. I plan on using a Martz front subframe. That way the subframe will already be set up for a LSX motor.
Any info on any part of the swap is appreciated.
Prior to selling my car I had looked into the ABS thing. The hardest part was getting a front reluctor wheel that would work with the 4th gen ABS computer.I had looked into using a C4 spindle or B-Body spindle. I dont remember if these have the same # of teeth. If I was still to do it I would probably have a ring machined. The electrical should not be too bad. Im not sure if the ABS module needs any signals from the body module.
