Sponsored by: DashLynx
HID Question
Old 11-17-2007, 05:16 PM
redss454's Avatar
Default HID Question
Hey all. I am looking at converting my stock headlights to HID. I have been doing research for my DD as well (04 Ram). I will be ordering from LEDgauges, but have heard that the HID conversions have problems with "strobing." Anyone experience this? Also, how hard was the install? Worth it?
Thanks,
Chris
Old 11-17-2007, 06:35 PM
The Black Pearl's Avatar
Do you have a Camaro or Trans Am?
Old 11-17-2007, 09:04 PM
The Guz's Avatar
Thanks,
Chris
The install is straight forward. It's all plug and play. As far as the strobing I have not experienced it. It can be attributed to a bad ballast or a poor ground. I use a relay harness which hooks up to the battery to provide full power to the HIDs when they are first turned on. HIDs use the most power when they are first turned on. Yes it is worth it. I use a kit in my 02 SS and my 99 Grand Prix. Worth every penny.
Old 11-17-2007, 09:59 PM
Copy & Paste Moderator
VIP1's Avatar
The problem with putting HID capsules into Halogen Reflector housings is glare. The Halogen housings can't properly focus and aim the light. Therefore the light gets sent out in a scattered beam.
Old 11-17-2007, 11:18 PM
The Guz's Avatar
Yes that is a problem. But some of us do not have the time or money to retrofit projectors. So our best alternative for poor light output due to the design of the head lamp is HIDs. Aim them properly to avoid blinding oncoming traffic.
Old 11-18-2007, 12:25 AM
italicizedsponge's Avatar
i like lighting up the roads for myself as well as everyone around me! but yeah it sucks for anyone in front of me
stock VS. HID
Old 11-18-2007, 08:48 AM
LS1 Terror's Avatar
strobing has not happened to me but to a couple of my friends and it was a bad ballast. one of my ballast went out completely on my car but the guy has a year warrenty and covered everything it was a non sponser.
Old 11-18-2007, 09:27 AM
redss454's Avatar
Thanks a lot guys. The Ram has a lot more problems doing the conversion,
and I wanted to make sure it was easier on my Camaro. I will be adjusting them good,
as I get annoyed by some with them in traffic, and don't want to be that guy.
Also, do you all have the hi and low beams? Or just the lows? I never use my
hi-beams, so figured it'd be a little cheaper to go that route.
(The Camaro has two seperate bulbs for the hi/low correct? Sorry for the newb question, I'm still learning haha)
italicizedsponge, what color temp is that? Is it as blue as it looks in the picture?
Thanks again,
Chris
Last edited by redss454; 11-18-2007 at 09:32 AM. Reason: Trying to make it easier to read
Old 11-19-2007, 02:01 AM
The Guz's Avatar
All you need is the lows. You can leave the high beams as halogen bulbs.
Old 11-19-2007, 06:41 AM
Thanks again,
Chris
its 10000K, all you need is the low beams (9006 bulb).
Old 11-19-2007, 09:12 AM
SparkyJJO's Avatar
Why don't you replace the high beams too? Is it because the HID is so bright you really don't need highs anymore, or is it because the HID kits for low and high are the same brightness?
Old 11-19-2007, 09:28 AM
VIP1's Avatar
You can't quickly flash HID. You wouldn't be able to flash your High Beam anymore to signal other drivers.
Old 11-19-2007, 09:31 AM
VIP1's Avatar
The K number is the color temp. It is not the brightness (well not directly, I'll explain). 4000K - 5000K is the brightest. Continuing up the color scale, the light gets bluer then purpler and the lumens output (the actual measurement of light) decreases. In other words, a 10000K HID kit is dimmer than a 4300K HID kit. Our eyes are least sensitive to blue light. Blue light also scatters more easily. In the end, we can see better with a 4300K HID kit for many reasons.
Old 11-19-2007, 09:55 AM
yea i know they arent as bright as 4300K but damn they light up the road and i like the blue so thats why i got them. i saw 30000K the other day just ugly they arent any brighter than stock IMO and are a deep purple
Quick Reply: HID Question
