Home made meth kit
Home made meth kit
I'm going to make my own meth injection kit using my wiper fluid container. I was wondering if my old factory fuel pump would make enough pressure to support the kit and if it would even work submerged in the 50/50 mix? (aka wal-mart windshield washer fluid)
Does anyone know where I could find a pump that will support 150+ psi? I know some of you guys have built your own meth kits, what pump(s) are you using?
its been done.. does it work?? yes.. is it perfect?? no.. theres a page floating out there on the internet of a guy who did it him self on a dsm with befores and afters.. but with kits available on ebay and elsewhere for 200 bucks.. why not just buy??
I'm not using the windshield washer pump, just the container. I was thinking of using my old stock fuel pump. I was thinking that if it was stong enough for 8 injectors and a small shot wet kit, that maybe it would have been good enough for a single .030 jet and nozzel. I,m going to test how much pressure the stock fuel pump builds without a regulator and then run it through a .030jet and see what the pressure difference is.
Because if i could build one for less than 100 bucks then thats another 100 in my pocket . Besides I have most of the materials just laying around in my garage, I thought I'd give it a try.
Thats the reason I was trying to build my own, but now I can't find the diy build he had on there. I think he built a dual stage kit now and has been running it for a couple of years without an i/c and no problems. But he is using a larger pump like the other guys are recommending.
