What would happen ?
What would happen ?
What would happen if i increased the boost on my car from 8 psi to 12psi with stock heads...i heard stock heads can hold alot of boost..Perhaps some personal experiences??
I ran it up to 12-13psi... on 42lb injectors... with a single Wallbro 255... With a good hook 1.54 60'. Ended up busting a ringland... I kinda knew I was pushing the limits, when I made my 607RWHP run there was a fair amount of "blow-by" of the rings... the fuel was pretty stable but not as low as it should have been. I wanted to be the first Rearmount in the 10's... and the only one on a stock block. Didnt happen however... best I could muster before I broke her was 11.01.
All that being said... I was on LQ9 stock truck heads (Dropped the compression a bit). If he is on stock heads and stock lower end, I wouldnt go above 10psi... and I would make 100% sure the fuel stays right.
Perfect thread for you... Hahahaha...
https://ls1tech.com/forums/forced-induction/817069-stock-block-13psi-7250rpm-pics.html
well i have a forged bottom end..its just i cant really afford awesome heads now and i need a tune..so i was debating if tuning it now will waste money because later on when i get heads i will need another tune, so im just seeing how much stock heads can produce..
Stock heads can handle 14 to 16 psi of boost, so you can indeed use them. We always use ARP head studs and GM MLS head gaskets.
You will naturally get more horsepower when you upgrade to better flowing heads, and you will indeed want to get the car retuned to take advantage of the heads. Bob
Ahhh I see... my mistake I should have looked at your sig closer. Most guys giving tunes will give you free updates... or updates for cheap. Changing out th heads wouldnt be a huge change to the tune... but it would be nessessary to have them re-tweak it some. So I guess your answer is two part... yes you can run that PSI on stock heads (use ARP Bolts for saftey)... yes you will need your tune tweaked when you swap your heads.
Jared
