rem/micronite gear and pinion
Old 11-19-2007, 10:34 AM
pushinfreight's Avatar
Default rem/micronite gear and pinion
Has anyone done this lately? I have seen where the t-56 gets done on a regular basis but not much on those who are doing it to the ring and pinion.
Old 11-19-2007, 11:24 AM
chicane's Avatar
I have been doing that process to all the Pro (off road) trucks for 10+ or so years now.
Questions ??
Old 11-19-2007, 11:51 AM
Black FormulaLs1's Avatar
ummm yea..how much does it cost, where do you get it done at? is it worth it? been tring to find info on this........
Old 11-19-2007, 12:20 PM
chicane's Avatar
Cost = about $150 for a gear set (your gears) from HRP. about $450 for a new gear set (purchased new, included with Micronite process) from Crane.
Where to get it done = HRP. Crane... Tex racing, Mark Williams also can do the process as well... you really want a set that hasnt has the pinion shaft done... as it effects the bearings interfearance fit.
Is it worth it = yup. no required brake in... lower oil temps... etc etc.
I do both the cryo and the rem process to gears sets when I get 'em done.
Old 11-19-2007, 12:27 PM
chicane's Avatar
Looky here: https://ls1tech.com/forums/showthrea...yo#post5429368
Old 11-19-2007, 12:42 PM
I was just looking to see if anyone had done it receintly. Should be getting a new rear soon and want to know of experiences. So If I am purchasing the rear as a whole unit will a place like HRP take the ring and pinion if it came out of an assembly?
Old 11-19-2007, 12:46 PM
chicane's Avatar
Yes... they will take them as bare components... just make sure they are clean.
I normally use a non chlorinated brake cleaner and then wrap them in news paper.
Old 11-19-2007, 12:48 PM
I am going to be going with a true trac application, should I only do the ring and pinion for the cryo and rem process?
Old 11-19-2007, 01:24 PM
chicane's Avatar
If you had the time, money and knowledge to disassemble/reassemble the unit... I would do the seperate components. It cant hurt... but the worms will need to be re-fit.
Old 11-19-2007, 03:37 PM
DrkPhx's Avatar
I had Roger at Vinci High Performance (sponsor here) Mikronite the ring and pinion for my 12 bolt. Not only is he very knowledgeable but very helpful as well. They will only process new units; not used. He recommends the "black box" Motive gear sets, so I ordered them directly from Strange and had it drop shipped to Roger. New gears were $154 from Strange and the process cost $250. Turnaound time was about 2 weeks. Here's a pic.
Attached Thumbnails rem/micronite gear and pinion-mikronite-gear-side.jpg
Old 11-19-2007, 03:39 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Originally Posted by DrkPhx
I had Roger at Vinci High Performance (sponsor here) Mikronite the ring and pinion for my 12 bolt. Not only is he very knowledgeable but very helpful as well. They will only process new units; not used. He recommends the "black box" Motive gear sets, so I ordered them directly from Strange and had it drop shipped to Roger. New gears were $154 from Strange and the process cost $250. Turnaound time wad about 2 weeks.
Keep us updated on that ... Apparently it should be quieter also..
Old 11-19-2007, 03:44 PM
DrkPhx's Avatar
They're already installed. Though there is still some whine, it's not as loud as with the original set.
Old 11-19-2007, 05:01 PM
Bad Blu Formula's Avatar
This is something that i've been looking into. Hopefully i can get this process done to my new gears sometime.
Quick Reply: rem/micronite gear and pinion
