Differential cover torque specs
Old 11-19-2007, 12:47 PM
fritzah's Avatar
Default Differential cover torque specs
Sorry if this has been asked before. I need to change my differential cover gasket again since it is leaking. Last time I did it I only used silicone. This time I bought the gasket from the dealer, does anyone really torque these or just tighten snugly. Thanks in advance.
Old 11-19-2007, 09:08 PM
miamifan3413's Avatar
Yeah be real careful with torqueing them down too much cause they can break off pretty easily.....happened to me already
Old 11-20-2007, 11:50 AM
nicks2ndz's Avatar
i torqued to 25 ft-lbs when i did the diff cover
Old 11-20-2007, 12:38 PM
fritzah's Avatar
Thanks.
Old 11-21-2007, 10:36 PM
Greystar's Avatar
With my aluminum cover w/ girdle I double up gaskets and torque to 25 ft-lb.
Old 11-21-2007, 10:49 PM
Shock Hawk's Avatar
Watch the torque specs especially if you have an aluminum cover... Aluminum can't stand the compressive stress that steel can and it will crack. I've seen it done to aluminum oil pans on bikes.
Quick Reply: Differential cover torque specs
