Drag Racing Tech
"race" switch panels
Old 11-19-2007, 06:34 PM
MetallicaMatt's Avatar
Default "race" switch panels
hey guys
well I finally have accepted the fact that my "street car" is becomming more and more of a strip car.
I've got about a million switches between my nitrous and all of the possible accessories you can think of, lights, and misc other switches.
I'm looking for some ideas on a trick switch panel. I'm running a full stock interior, with the addition of the 6pt roll bar.
I've seen every possible nitrous switch panel out there, and none are going to be big enough. I plan on making something myself. Luckily I have access to CNC machines and a laser.
Anybody out there have some pictures so I can get some ideas? I don't want to cut or drill the interior in any way. Its a very clean setup so far.
Right now I'm figuring I'm going to have to make some kind of arm to hold the panel.
Old 11-19-2007, 06:35 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
check out this guy
http://www.12voltguy.com/promod.htm
he has lots of panels and can custom make anything you want.
Old 11-19-2007, 07:07 PM
looks like he does good work, but my problem isn't making a panel, its more of where the hell to put everything so I can shift, use the passenger seat and have it still look tasteful...
Old 11-19-2007, 07:13 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Thats gets tricky since im assuming you still have heater controls, a radio and a center console.
I think your best bet is a top mounted roll bar panel it's out of the way but still has everything you need.
Old 11-19-2007, 07:17 PM
well I don't have a halo bar to mount too, that would be perfect.
I'm almost considering making a retractable arm connected to my 6 point somehow...
Old 11-20-2007, 08:38 PM
nobody has a trick setup?
Old 11-20-2007, 08:50 PM
fash00's Avatar
search for jimmy jams i think it was.Had them back when my car was still 6 speed nitrous motor its 4 buttons and a purge that go in the ashtray pretty trick setup actually i think i still have mine somewhere if your interested
Old 11-20-2007, 09:05 PM
yeah i've seen those long ago, i have over 8 buttons...
Old 11-21-2007, 08:29 AM
stroked30th's Avatar
Give Gil @ Speedwire Systems a shout! Best stuff around!
Old 11-21-2007, 09:58 AM
NSTY WS6's Avatar
Just a thought, b/c I've considered doing this myself. Make a panel that goes in the center console storage compartment. It's not hard to get to, and since you dont have a halo type cage it will still be easy to look to your side to turn things on before the run, purge would be easy to get to.. etc
However, if it doesnt have a/c you could make a panel to fill in there, and you could fit 8 switches there, just have to use some smaller toggels. That would still look clean IMO
Old 11-21-2007, 03:54 PM
yeah i've considered the center console, it'll just get a lil tricky with my line lock and stuff
it'd be nice to have something i could reach quickly, incase I need to shut it off
maybe i'll use this long weekend to figure something out...
