Drag Racing Tech
pullin wheels off the ground ???
Old 11-19-2007, 07:18 PM
rob scott's Avatar
Default pullin wheels off the ground ???
i have a some what stock 98 and im shotting to get it to pull the front wheels when i launch it. i need to know what i need to do to the car for it to pull with stock ls1 block with a 232/232 cam heads and 3600 stall and 9in with like a 4.10 gear? i dont want to drag the bumper but that would be great i just want a lil lift even one wheel coming off the ground. if there is a better cam for the car to pull. i'm not that great with cams/heads.
Old 11-19-2007, 07:29 PM
NJSPDER's Avatar
pulling the fronts is all about traction and weight transfer. what do you have under the rear of the car and what are you planning to do to get more grip out back?
i would suggest a bigger stall, think 4000-4400 and take advantage of everything that engine has off the line.
Old 11-19-2007, 07:37 PM
chrismorales75's Avatar
Add some nitrous.
Old 11-19-2007, 08:06 PM
brandonppr's Avatar
just some suggestions. It should not take all of these to do it because I did it with a 231-237 TSP cam stock rear 3.23 LS6 intake headers and removed front sway bar with stock SS wheels all the way around and ET streets on the rears. It pulled about 2"s off the ground. Stock rear suspension besides LCAs. Stock TA. 4L60e with a tci 3500. Also some weight reduction and battery relocate.
If you still have a front sway bar take it off
Sticky tires
Spool
Short TA
Lose as much weight as possible off the fornt
Transbrake
90/10 front shocks
Old 11-19-2007, 08:10 PM
LilSlo1's Avatar
My car runs 12.50's and just barely hops the left front tire off the ground when i leave.
Mods:
ET Drag radials
TCI 3600 stall converter (only getting 3,300 flash when I leave)
full lenghts, offroad Y-pipe with a cutout.
stock 3.23 gear
no front sway bar
Full race weight 3680 (with me in the car)
UMI lower rear control arms
UMI Frame ties
Stock internals
Ls6 intake
Old 11-19-2007, 09:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
!front swaybar
QA1 R shocks up front
Sticky rear tires
I was lifting fronts when I was going 12.4.
Old 11-19-2007, 09:18 PM
NJSPDER's Avatar
12secondV6 yanked his front tires on a 13.5 N/A run with a 1.7xx short time last year.
i think everyone is pointing to the same key, it si a traction thing. put the power on the ground and it will put the tires in teh air.
Old 11-19-2007, 09:23 PM
James Montigny's Avatar
!front swaybar
Sticky rear tires.
That'll do it Ask me how I know
Old 11-19-2007, 11:54 PM
daniel6718's Avatar
!front swaybar
Sticky rear tires
no way im deep in the 10's with stock front adn rea springs...aftermarket lca and relo brackets and front runners down in the 33xx range and still cant get them up...im goana get some shocks soon!
Old 11-20-2007, 12:30 AM
Dave J's Avatar
get some qa1`s and you will pull em nice
Old 11-20-2007, 12:53 AM
brandon1221's Avatar
my car is heads/cam, 3200 stall, stock 3:23 gears and stock shocks/springs and it still lifts the at least the front left tire every time. I do have !front sway bar and 15x3.5 pro stars.
Old 11-20-2007, 01:18 AM
JRracing's Avatar
Weight transfer is the key I think. No swaybar, good shocks and good tires should put you there. Oh and a bigger converter.
My pig cuts 1.50 60's on the spray and barely lifts the fronts for a sec. 3600+ lbs street car with a/c. lol.
Old 11-20-2007, 09:29 AM
Retired Street Racer
Matt D's Avatar
Sticky tire, negative pinion angle on the TA, drag shocks set on loose, and you will lift them if you hook.
Old 11-20-2007, 09:47 AM
dlove's Avatar
1.48 short time and i dont even pull mine an inch.
3000lbs
!front sway
front qa1's at 4
LCA
sphon TA
rear air bag 35psi
lakewood 50/50 rears
M&H 28'' tall, 17'' DR
Im glad it doesnt pull them, put everyone wants a good wheelie every once and awhile
Old 11-20-2007, 09:48 AM
LS1Tech Co-Founder
My car in 2000 GMHTP Shootout at Bristol:
Old 11-20-2007, 10:15 AM
LilSlo1's Avatar
Wow, I wish photo magic would have been able to catch my left front off the ground. I guess their camera guys aren't fast enough.
Old 11-20-2007, 08:03 PM
WS6HUMMER's Avatar
Originally Posted by chrismorales75
Add some nitrous.
AMEN!
Old 11-20-2007, 09:03 PM
rob scott's Avatar
i would like to get my z to launch like matt d's. so what about rear shocks? leave them stock? im having the trans built and cam/heads done at the same time in the spring if i can deside on the cam and heads for it, i dd it now but im going to turn it into a weekend track car for my dad and i. but i also want to take it out some time and kill some of the kids around here. im getting a 9inch for it to, i just want to launch hard
Old 11-20-2007, 09:10 PM
Matt D's Avatar
EDIT: Under my profile, click on my homepage. It lists all of my mods.
Old 11-20-2007, 11:52 PM
easiest way to pull the tire is with a jack
Quick Reply: pullin wheels off the ground ???
