does this look right (pic)
Old 11-19-2007, 11:11 PM
Rickys S/C Z28's Avatar
Default does this look right (pic)
i took off my head unit tonight and took some pics, just wanted to run them by you guys and see if it looks right, this is my first time working on an LS motor, and the first time working with FI so if any thing looks out of place plaes tell me thanks
Ricky
thats the only way i could get it off
Old 11-19-2007, 11:13 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
the flux capacitor in the lower pic looks like it should be replaced.
Old 11-19-2007, 11:22 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I usually leave the J bracket on the car and take the head unit off the J bracket by removing the allen head bolts. But, yeah, it looks to be mounted correctly if that was your question? You may have to reclock it a bit depending on your intercooler piping... My outlet almost faces straight down, but the piping will dictate the ultimate direction.
Old 11-19-2007, 11:51 PM
yes the J bracket was a bitch to get off with the head unit, but i did not have much of a choice, the allen head bolts look to be messed up? can i replace the allen head bolt with any kind that will fit??
ha ha ha ha come man
Old 11-20-2007, 12:01 AM
kp
kp's Avatar
How did get that standoff loose without taking the head unit off
You can replace the allen bolts but make sure they are the same length.
Old 11-20-2007, 12:06 AM
ok cool man by the way whats the standoff?? is that the long nut looking thing in the bottom pic??? if so i just unscrewed it till it came off?? i hope i did not mess anything up?
Old 11-20-2007, 12:23 AM
kp
kp's Avatar
The bolt behind the blower must not have been very tight. Its a lot easier to take the blower off the bracket first as mentioned
Old 11-20-2007, 12:36 AM
trust me is was hard as a **** to get it off, im going to try to get the J bracket off the head unit eather tonight or in the morning ill take more pics as i go
thanks KP
Old 11-20-2007, 12:43 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
check the tools/fabrication section.
someone sells a special tool just for the procharger guys, looks pretty cool.
Old 11-20-2007, 01:05 AM
can you post a link to it?? i looked but seen nothing?
Old 11-20-2007, 01:07 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
here you go
https://ls1tech.com/forums/showthrea...er#post7495127
Old 11-20-2007, 01:35 AM
sweet man thanks!!!!!!
Old 11-20-2007, 02:21 AM
ok cool i got the J bracket off and the allen bolts are good they just looked bad and i did not want to take a chance of messen them up!! but i am learning as i go
now time to clean this bad boy up!!
Old 11-20-2007, 06:32 AM
blown98z28!!'s Avatar
If you replace the socket heads, you need to make sure you get new ones that are the same strength and have the same coating. Any type of socket cap of the same size will not do. Just FYI if the issue ever comes up again.
Old 11-20-2007, 07:01 AM
thanks buddy
Old 11-20-2007, 12:56 PM
kp
kp's Avatar
The stock ones are stainless I believe, wouldnt be a real good idea to use anything that can rust..
Old 11-20-2007, 06:41 PM
great Kp thanks!
Old 11-21-2007, 02:31 AM
Default more pics! any help or all good
Old 11-21-2007, 02:33 AM
not to bad for 2 days work(i think iv had my cherry popped! hahahahah hope to get the heads off tommarrow
