Drag Racing Tech
View Poll Results: What Shocks to Run
Afco
59.62%
Strange
9.62%
QA1
30.77%
Voters: 52. You may not vote on this poll
What shock would you run
Old 11-20-2007, 12:20 PM
T Pizzle's Avatar
Default What shock would you run
I am building my true ten five car and I see allot of people running QA1's, Strange, and Afco's. What would be the best shock.
Front and Rear
Old 11-20-2007, 12:36 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Run the best that your budget will allow....
it sucks having to buy something 2-3 times because you need more adjustments or are unhappy with the results.
Old 11-20-2007, 12:46 PM
Fireball's Avatar
for a true 10.5 car....AFCO without a doubt...
Old 11-20-2007, 01:21 PM
T Pizzle's Avatar
I am not worried about the price. I just want the best
Old 11-20-2007, 01:26 PM
3fingas's Avatar
At minimum Afcos on the front. IMO
Old 11-20-2007, 02:11 PM
chrismorales75's Avatar
I think afco makes the best quality product out of those 3 brands.
Old 11-20-2007, 02:19 PM
LS1TECH Sponsor
Steve Burger's Avatar
Afco. I have QA!s but if I changed it would be Afco.
Old 11-21-2007, 09:32 AM
DOTracer's Avatar
If it's a quick TT5 car with a good deal of power, then Afco or Santhuff.
Old 11-29-2007, 01:07 PM
LS1TECH Sponsor
We have AFCO on sale right now. Let me know if we can help.
Old 11-29-2007, 05:40 PM
studderin's Avatar
should-afco
afford-
Old 11-29-2007, 09:50 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Any car that is a race car i would go afco.
Old 11-30-2007, 08:04 PM
LS1TECH Sponsor
CutlassRacer's Avatar
Affco, then Strange, then QA1 from that list.
Old 11-30-2007, 08:37 PM
jmill96Z's Avatar
I run QA1's right now, and I'm not really that impressed. I'm saving up for a full MADMAN suspension with afco's when I get back down to the lower 48 in 09 .
Old 12-02-2007, 09:23 PM
RAGENZ28's Avatar
I'd say either Santhuff or Afco, even though Santhuff wasn't listen it is still a quality piece.
Old 12-16-2007, 07:30 PM
CanuckSS's Avatar
I would like to know why the afco's are better than the strange shocks. They are about a 100 bucks more/shock. Is it the adjustability. Thanks for any input.
Old 12-16-2007, 08:27 PM
Hrod382's Avatar
I'm adding about 200 HP to my car this winter and it'll be in the 5.60's range 1/8 mile, it was fine with cheapy comp engineering fronts running 5.90's until they finally wore out. I'm a college student so if I can get by with cheapy Koni's (non coil over) I'd like to but if it helps launching straight/consistancy I'm all for Afcos.
Good thread, I almost started this same one a few days ago.
Old 12-17-2007, 09:50 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
AFCO has the best valving if you look at dyno tests. its just a bit better for the guy that knows what they're doing when doing adjustments. right now i have the Strange shocks on my own cr, but will be selling them off to run the AFCO's sometime in the future.
keep in mind... the Strange shocks have both adjusting ***** on the bottom of the shock as to where AFCO's have the extension adjuster on the top, and the compression adjuster on the bottom. the extension adjuster on the top of the AFCO shocks can be a pain to get at for adjustments. you can cut a hole in the shock tower to access it better on the front set, the rear set will be inside the car where the shock bolts in the car.
look me up when you go to buy... i have the best deals out there on all of them.
Old 12-17-2007, 04:46 PM
NJSPDER's Avatar
lakewood 50/50 on the rear and anything but the QA1 set up that uses the stock upper perch in front.
Old 12-18-2007, 10:39 AM
BMR Suspension's Avatar
Money being no object Santhuff........
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 12-25-2007, 04:24 PM
Hrod382's Avatar
Ok I'm sitting on massive christmas money so I'm going to buy my shocks for the front. I know a lot of you mess around with all kinds of cars so I figured I'd post this up for my specific case.
This is going on a '67 Camaro stock front stub car. I'm thinking about the DA Afcos, with those can I adjust on them with the car on the scales and change the weights around or do I need the QA1 Coil over setup? I want a setup that's good for consistancy as well as adjustability although we'll probably only screw with it a few times and be done. I'm a poor college kid so I'm all for taking in advice before I dish out $350+.
EDIT: Just got my answer on the scale question, is it worth the extra cash to go to a coil over setup in your opinions?
Quick Reply: What shock would you run
