Gears & Axles - axles from a 2.73 rear fit in a 3.42 rear?
tording99Z28
11-21-2007, 05:24 PM
I currently have a 99 Z28 A4 with a 2.73 rear in it. I am getting a M6 rear with the 3.42 rear gear in it. The guy that is giving me the M6 gear says I will have to use the axles out of my 2.73 rear because he does not have the backing plates. Will the axles from the 2.73 rear fit in the 3.42 rear?
ZONES89RS
11-21-2007, 07:58 PM
If it is the same year style, yea.
1BADASS35th
11-22-2007, 08:35 PM
Yes they should work out for you. Are you planning on installing this new rear end with the 342 gears into your car?
tording99Z28
11-23-2007, 08:32 PM
Yes I am planning on puting this rear in my car. Since I made this post I have done some more research and now understand. Tyson told me to use my axles because he does not have the backing plates from the 3.42 rear end. Instead of having the plates pressed off of my axles and put on the 3.42 axles it would just be easier to put my axles in the 3.42 rear which makes sense. I have already checked on the TCS too and the 3.42 rear is a 4 channel rear which means it had TCS and so does my car so it should just bolt right in and all I have to do is hookup the ABS/TCS sensors on each wheel from my axles/backing plates and it should work fine.
BriancWS6
11-23-2007, 08:41 PM
:nod: Sounds like you have everything going now. Enjoy the new gear ratio:chug:
