VHT Trackbite to help with belt slip.
Old 11-21-2007, 05:59 PM
2001WS6Vert's Avatar
Default VHT Trackbite to help with belt slip.
After a couple of runs at the track I would sometimes get a little belt slip. The boys at RMCR told me to try putting some VHT on the belt. With a small brush I applied it with someone tapping the engine around. It stays very gummy. It works like a charm for me. I'd thought I'd post it here because I have not seen it mentioned before.
Old 11-21-2007, 06:38 PM
ninetres's Avatar
Wow. Sounds like a great idea....as long as it don't harm the belt over time.
Old 11-21-2007, 06:59 PM
HUNTER02SS's Avatar
Great Idea. I bet it make's a mess on the underside of the hoos though. As long as you don't cake it on it would be alright ,I guess! Good Idea though.
Old 11-21-2007, 07:16 PM
platinum1's Avatar
i have been doing that for a few years now.it works well and does not harm the belt!
Old 11-21-2007, 07:20 PM
It really doesn't make a mess like you might think. It's so tacky that it mostly stays with the belt.
Old 11-21-2007, 07:42 PM
kp
kp's Avatar
Problem is it works only a short short time, after a while a lot of dust and whatever it picks up sticks to the belt. I've used it in the past and it works enough to verify the slip and make a couple good passes.
Old 11-21-2007, 07:53 PM
Got Me SOM's Avatar
Good tip!
Old 11-21-2007, 09:09 PM
Ari G's Avatar
Have fun cleaning it
Old 11-21-2007, 11:01 PM
Jimmy P's Avatar
It has been posted here alot, but is usualy used to diagnose a belt slip problem. I dont think anyone uses it regurarly.
Old 11-22-2007, 05:14 AM
It's not a cure all. I go to the track 4-5 times a year and run 3-4 times each time. I didn't want to switch to a cog drive or get into major re-engineering. It can help if you have minimal slip and don't race all that much.
Quick Reply: VHT Trackbite to help with belt slip.
