what is needed or what do i do??
I would love to drive to the track and run 9s on DR what is need to do this....
the car is a 95 T/A 3700+lbs
355 with YSi
4l80e 3400 scyank stall
3:70 gear
looking at maybe 800rwhp
coyuld this be done on a 275 or would a 315 be the way to go
355 with YSi
3:70 gear
275 you wouldn't have to do a single thing to make the tire fit as long as you use the right offset.
It will be way easier to run that on a 315, but you'd have to mini tub unless you want it sticking out and having the car sit high.
The tire size alone gives you a big traction increase, plus 30" tires look bad *** on our cars.
Torque arm, moly control arms, relocation brackets, front and rear adjustable shocks with after market springs, adjustable panhard rod, HD drive shaft, drive shaft loop, after market rear end, good HD anti roll bar, cage and window next plus other necessary safety stuff.
