What gear do i need
First, we need to know what rear end you have.
Is it a Strange 12-bolt? I'm guessing because they come with the S/T series axles you referred to.
What gears does it have right now? This is important so hopefully we can determine what series carrier is in it.
IF.....if you have a 12-bolt with 4.11's in it, right from Strange, it will have a series-4 carrier in it. If you want to put 3.73's in it, you will need the thin cut 3.73's for the series-4 carrier.
