Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
305 question
Old 11-23-2007, 07:20 PM
84z28Camaro's Avatar
Default 305 question
Does a 305 use a 283 block? And are there any aftermarket 305 blocks? I doubt there are many but just kind of curious
Old 11-24-2007, 12:11 AM
In-Zane Moderator
ZONES89RS's Avatar
A 305 is a 305 block last i checked. No aftermarket for the lil guy.
Old 11-24-2007, 03:45 PM
1997bird's Avatar
The 305 has a 3.736" bore and a 3.48" stroke crank. The 283 has a smaller main journal diameter than the 305, with a 3.875" bore & uses a 3.00" stroke. A 307 block has a 3.875" bore with a 3.25" stroke crank and has the larger main journals like the 305 & 350's. http://en.wikipedia.org/wiki/Chevrol...l-Block_engine
Old 11-25-2007, 08:16 AM
thirdgenbum's Avatar
this is true.
why would you want an aftermarket block though? they are a dime a dozen at any local boneyard...
Old 11-25-2007, 09:59 AM
redss454's Avatar
Even better, why not go with a 350? More cid, more parts availability, same outside dimensions, and more power? The 305 was one of the biggest pigs I've ever drive (no offense, just MHO).
Chris
Old 11-25-2007, 10:30 AM
In-Zane Moderator
ZONES89RS's Avatar
I love the guys that build the 335 strokers, what better way of saying "I just wanted to waiste some money."
Old 11-25-2007, 04:11 PM
cherryelky305's Avatar
the 305 was a bad motor and i got rid of it for an ls1, but there is still a place in my heart for that ol '305 sitting in the corner. I think I might do something with it one day.
Old 11-25-2007, 06:01 PM
87gnx's Avatar
We did a '87 Monte SS swap w/a 383 (350), everything power steering, a/c, wiring all changed over easily.Noticed a huge difference afterward,was like a new car!. f.w.i.w.
Old 11-25-2007, 06:02 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Burn it...
Old 11-25-2007, 06:15 PM
Originally Posted by Beaflag VonRathburg
Burn it...
Im thinking more like a table or work bench or something.
Old 11-25-2007, 06:24 PM
FireHawkMike's Avatar
dont waste your money
Old 11-25-2007, 06:39 PM
redss454's Avatar
I would love to have one of these in my living room.
Chris
Old 11-26-2007, 12:01 AM
In-Zane Moderator
ZONES89RS's Avatar
!!!!^^^^ I totally think i might have to do that one day!!!
Old 11-26-2007, 12:45 AM
I kind of like the idea of a well built 305. And I know it won't ever be as fast as larger displacement engines but people wouldn't believe a fast 305 existed and it'd be cool to be like yes it does.
Old 11-26-2007, 12:58 AM
transamkid1985's Avatar
i say go with the coffe table idea
Old 11-26-2007, 03:37 AM
I assure you I know how well built 350 + can be built but if I go that route I'd want to get a good solid block and that'd cost me more. I'll probably go with the built 305 for awhile then get a different block + heads. 305 is a lot cheaper cause you can use vortec heads for very effective results
Old 11-26-2007, 04:08 AM
In-Zane Moderator
ZONES89RS's Avatar
Man, the thought of building a 305.....just couldnt bring myself to do it.
Old 11-26-2007, 04:27 AM
i'm talking to a guy that's helped build several 305's, guy he knew made quite a bit of money making bets on how fast his 305 was.
Old 11-26-2007, 07:02 AM
408z28's Avatar
Why would you use a 64cc chamberd vortec head on a motor that came stock with a 58cc chamber head?? You'd be running like 8.5 to 1 compression.
I used to run 305's in a street stock (circle track car) because that was the rules. I felt gay calling summit and ordering 334 ci pistons for a stroker 305. I wouldn't ever think about putting a 334 in a street car, but for a race class thats's rule book states "you must run a 305 block w/ readable casting #'s", it made it a little bit easier for me to run up front. Ive got 3 complete 305 roller (87-92) motors at the house, and the only reason I keep them laying around, is for weigh outs, mock ups, clearance work for chassis, or for making a body a runner/daily driver. I wouldn't waste my $$ if I were you.
But thats just my .02.
And by the way, 350 pistons (forged or hyper.) are about half the price of 305 pistons. Cranks and rods are the same price...so...their more expensive.
Quick Reply: 305 question
