1FST99Z
11-24-2007, 07:10 AM
Just as the title says. I found out that is what is the only other thing that can be wrong with my clutch. we adjusted the clutch. bleeded the master and still it is hard to get in gear. well come to find out when my last clutch puked one of the springs it got caught between the pressure plate and the flywheel. causing serious scaring to the flywheel. so they cleaned it up and used a shim to get everything correct. well it looks like the shim wasnt enough. so instead of getting another shim I would rather have a newer flywheel that has never been turned and in good working order. thanks in advance.
Wesley
Wesley
