y-pipe question
Old 11-24-2007, 08:40 PM
S-sguy's Avatar
Default y-pipe question
when u install a aftermarket y-pipe, does it attach to the cats or do you have to remove them
Old 11-24-2007, 08:58 PM
ae13291's Avatar
you can either buy a catted y pipe or usally everyone gets the straight ones, it is also possible to fabricate ur own with cats
Old 11-24-2007, 10:37 PM
RedRallyeZ's Avatar
if you are getting a new y-pipe and still using your stock manifolds, then the gain is not worth the money.
but yeah you can get a new y with new hi-flo cats in it already, best option if you need to keep them
Old 11-26-2007, 08:50 PM
S-sguy's Avatar
do you think in will make it any louder i already have a slp resonator dumped
Old 11-26-2007, 09:13 PM
RedRallyeZ's Avatar
not sure what you're referring to,
removing the cats=louder
switching y-pipes and keeping cats=probably not, nothing truly noticeable anyway
Old 11-26-2007, 09:23 PM
ms4z28's Avatar
ya you should jus get headers and take off the cats with slp resenator it will have a real nice sound i recomend slp long tubes or pace setter long tubes slp make a little more power but they hang low and they hit the ground alot....
Old 11-26-2007, 09:37 PM
RedRallyeZ's Avatar
not real sure about SLP making more power, yes they claim more power, but 41rwhp from a header swap is a little high,
I personally think that the best deal out is QTP, i personally have XS, but there is enough info on headers on this site to answer ALL your questions, just hang out in the Gen III external for awhile
