what studs and lug nuts are being used ??
What studs and lug nuts are being used on 15 X 10 Weld Prostars???
Please give part numbers if possible...
Looking into the ARP or the Moser studs and either closed or open ended lugs but do not know what type of lugs???
thanks
thanks
1.310'' Mag Shank - open end
ARP # 070-100-7713 .509'' Knurl Wheel Studs Late GM (F-body, Corvette) 12mm x 1.5 3.250" long
Those are for stock axles.
"All Motor 9 Second club member"
If you are going with 1/2" studs it'll be the ARP #100-7703 studs and part#63004 McGard lug nuts.
http://cgi.ebay.com/ebaymotors/ARP-1...spagenameZWDVW
Good luck!!
Good luck!!
