Soft crankshaft?
Soft crankshaft?
I just got donw putting back together a 1997 5.7 vortec in a Chevy 1500 truck It had a pretty bad spun rod bearing and I had to get a reman crank and new bearings and 4 of the rods got reconditioned. Started it up and it ran good except a little miss but got that taken care of it ran for about 30 mins then we took it for a drive. It throw a rod and head no evidence of a spun bearing.... do cranks ever have soft journals like cams have soft lobes not to mention the machine shop gave us the wrong gasket kit and timing chain it was for a pre 1006 any chance the crank was soft?
Thanks
Thanks
Hrmm, maybe possible, but most likely a badly machined crank. I've had this happen to friends of mine before. Put a .010/.010 crank in, engine runs for 5 minutes, then, clunk, clunk, clunk. All on stock non-performance motors.
How do you figure a soft crank caused a thrown rod?
The only thing that would do is wear the journal down faster.
I've seen a lot of turned cranks put in and waste bearings because the oil galleys are not properly cleaned, but you say there was no sign of a spun bearing.
I'd say it was a weak or over torqued rod bolt.
Why would you only recondition 4 of 8 connecting rods? Thats an expensive mistake. I agree with 8a8mfh on a weak rod bolt. You would have to have a crank that was turned .030" or more before running into a problem with the crank. Did the motor start knocking while you were out driving the truck just before the rod let loose?
Double check and make sure the rod was not installed on the piston backwards
