Pacesetter passenger side LT clearance Question with PIC!
Old 11-25-2007, 05:08 PM
Spiewalk's Avatar
Default Pacesetter passenger side LT clearance Question with PIC!
Ok guys, I haven't finished tighting all the bolts, I can probably get the header to rise about another 1/4 to 1/2 inch but generally speaking does the passenger side hang lower than the driver side?
Old 11-25-2007, 06:41 PM
Spiewalk's Avatar
anybody? ttt...
Old 11-25-2007, 07:02 PM
2_wacko's Avatar
The passenger side sits a little lower then the drivers side.
Old 11-25-2007, 07:19 PM
EastTnZ28's Avatar
I have the same headers and they look the same as yours.
Old 11-25-2007, 07:33 PM
Spiewalk's Avatar
Wow, that makes it the lowest point on the car, sort of... Either way, like I said I can get it a 1/4 to 1/2 inch higher when I tighten the bolts I was doing it alone with a rope tied along the tubes and my arms and hands got tired as ballz. Tomorrow it is!
Old 11-25-2007, 08:47 PM
g-ryde1's Avatar
not sure if this is gonna help you out too much but this is what mine looks like bout the same.
Old 11-25-2007, 09:15 PM
Spiewalk's Avatar
Looks the same, thanks guys!
Old 11-25-2007, 09:47 PM
JL8Jeff's Avatar
Yes, passenger side sits lower, but the driver's side of the y-pipe drops down to clear the floor brace so both side sit around the same height. The picture above shows the driver's side y-pipe dropping down before it wraps around to the center of the car.
Old 11-26-2007, 06:07 PM
penningta's Avatar
did you get ones with egr or full race ones
