new rusty flywheel? repair?
Long story short I left my brand new flywheel out side an it got rained on. Had some surface rust. I sprayed it with brake parts cleaner on both sides and used a small plastic brush (kind you use for bathroom) to get most of the rust of. Then hit it with WD40. I was thinking of using a shot of anti-rust gel and a wire wheel connected to my drill to make it look like new again. Is this advisable or is there something else I should be doing?
I wouldn't hit it with the wire wheel, that could possibly remove more material than you need to....
Like was said, if it was just surface rust, you should be fine. If it was a bit more than surface rust, I'd have it surfaced.
-Will
-Will
LS1TECH & Trucks Sponsor
Agreed, for surface rust just do it yourself with some fine sandpaper. For even the slightest pitting, get it cut.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
