T-Top Problem!!!!!
T-Top Problem!!!!!
My T-tops are leaking. They are leaking at the weather stripping right where it connect at the part closest to the front left tire on the drivr side and the front right tire on the pasenger side. Any HELP??????
Re: T-Top Problem!!!!!
SiggyBaby nice car .It only leaks when it is raining. I have never aplied direct pressure to the weather stripping, I didn't want to do that because the owners manual said not to.
Thanks. If it's leaking when in rain then you must have a decent sized gap around the weather stripping. None of mine have ever leaked in rain and this current Z of mine never did either when I drove it everyday. Pressure from a car wash did cause it to leak some but not much.
SiggyBaby, thanks for all the help, the guy at the dealership says that I was missing a little on the edge were it was leaking from. He said it was tiny, that was why it only leaked when I was moving, because the water would accumulate in the area and leak in. I also would like to know where you bought your Zaino Products, I HAVE TO HAVE THEM !!!!!!!! How do you like the loudmouth?
Contact Sal Zaino at his email zainobros@zainobros.com and ask for information on a distributor in your area. Or you could order them directly from Sal.
Thanks for allyou help SiggyBaby. I was going to get my stripping replaced today but the gy doin it said it was almost brand new. I said, well it isnt holding out the water too well! He answered back that it was off on the left side by 2mm, tat lef a 2mm wide gap, and let water leak in. On the right side there was a 1mm gap etc. Well long story short, it was fine, the guy who said I was missing a piece was an idiot, and it works fine now. With all this Florda rain, sure enough, I tested iton the way back home.
