Moser Axle-Which gears for street?
Old 11-25-2007, 09:35 PM
74chevystepside's Avatar
Default Moser Axle-Which gears for street?
I have a 6 speed 2002 T/A. I would like to up grade the rear axle. I know the 4.11's are very popular, but I would like to get comments from you guys on what you guys prefer. Would anyone prefer the 3.91's over the 4.11's for a street application?---Thanks
Old 11-25-2007, 11:31 PM
Rastoff's Avatar
I have 3.73s in my '96 Formula 6 speed and wouldn't trade them for 4.11s unless I was going to the track. With this gearing the car comes off the line nicely, but not overbearing.
If you only use the car on the weekends the 4.11s would be lots of fun. For a daily driver the 4.11s would just be too much.
This is all just my opinion of course.
Old 11-25-2007, 11:51 PM
black hills tj's Avatar
i have 4.11's on my daily driver...
granted its a jeep with a 5spd and 33's
Old 11-26-2007, 11:39 AM
Jays00ss's Avatar
I had 3.90's in my 10 bolt always wished I went to 4.10's. When I changed my rearend,I put 4.30's in my 9" and absolutely love them!!! 2150 rpm @75 in 6th with 275/35/18's in the rear. I will need a taller tire at the track when I get my cam put in though.
Old 11-26-2007, 01:27 PM
Talking
Thanks guys for your input thanks for your time----Alan
Old 11-26-2007, 01:30 PM
Would you guys still agree on 4.10's even if you had a Procharger (of course i would up grade to a 9 inch)
Old 11-26-2007, 01:35 PM
Ericbigmac83's Avatar
street application 4.10s will be ok, track you'd want the 3.9's or even 3.73's or youre gonna need to spin the motor to high hell or get a taller tire. if you do a lot of highway driving it would also be a lot easier on you with the taller gear depending how loud your exhaust is
Old 11-26-2007, 03:37 PM
chrismorales75's Avatar
You'll run fastest in the 1/4 with 4.10's with a stock motor or motor with a few bolt on items.
As far as daily drive ability 4.10's are fine, people that tell you it's too much gear or bs like that are smoking crack
The difference from stock gears 3.42 to even 4.10's is only a few hundred rpm at 65 mph. Remember 6th gear is .50 overdrive so even if you get 4.10's it's a 2.05 final gear ratio.
Get the 4.10's you'll really notice the difference.
Old 11-26-2007, 05:24 PM
LS1TECH Sponsor
Steve Burger's Avatar
4.10 and a six speed is a good all around combination. Add stickey tires or even drag radials and you may have life expectancy issues with the 10 bolt.
Old 11-26-2007, 05:26 PM
1madss's Avatar
Been driving on 4.11's for about 7 years now in my daily driver. Sometimes as many as 1500 miles a week, mostly highway. 80 mph at 2200 rpm.
Old 11-26-2007, 05:57 PM
Life expectancy of a 10 bolt with 4.10's and 6000 rpm clutch drops are less than a fly's 1 day life
Old 11-26-2007, 08:23 PM
slick1851's Avatar
My 4.10s were perfectly fine in my car
Internet has to much BS on it
I love them, great gear
slick1851's Avatar
We have 6speeds, not 5speeds you have to rember that also
