View Poll Results: Which Shifter
Hurst Billet/Plus
16.67%
Pro 5.0
66.67%
B&M Ripper
16.67%
Other please state
0
0%
Voters: 18. You may not vote on this poll
Shifter?
Old 11-26-2007, 09:14 PM
SS4Luck's Avatar
Default Shifter?
I have an 02 SS with the stock hurt shifter... i recently blew the **** outa the whole 3-4 assembly and most of the synchros which i was told was primarily from overshifting caused by powershifting...
so for xmas i wanna get a new shifter with jam stops and the whole 9 yards...the problem is picking which one...
my dad is old school and thinks hurst is the only way to go... but idk cuz i have no experiance with the B&M or the 5.0..
so wut does everyone else think based on experiance...
Old 11-26-2007, 11:31 PM
whyte95ZRida's Avatar
I'm running a Pro 5.0 and I love it. Shifts are quick and precise.
Old 11-27-2007, 12:40 AM
TARZAN's Avatar
I'm running a Hurst and have no complaints
-Will
Old 11-27-2007, 06:49 PM
KurtRardin's Avatar
I just installed a Pro 5.0 last night in my car and so far I really like it. I had a hurst shifter in my 96Z and I thought it was equally as good. If I had to pick between the two I would just go with the cheapest, because in my experience they both feel about the same.
Is the stock hurst shifter the same as the aftermarket hurst shifter?
Old 11-28-2007, 12:05 AM
02 Camaro SS's Avatar
No way is the Hurst as good as the Pro 5.0. I've never used a B&M Ripper, it's supposedly very similar to the 5.0 but the Hurst feels so rubbery to me now after switching to the 5.0.
Old 11-28-2007, 02:57 AM
02Z28LS1's Avatar
i've got the Pro 5.0 with Lou's Short Stick, and it's working great for me....but many people love the B&M Ripper better than the Pro 5.0.
from what i hear, the B&M Ripper is a "smoother" shift, and the Pro 5.0 is "notchy" (i can verify that to be true of the Pro 5.0 from first-hand experience).
if possible, see if you can find other people in your area that have each shifter, and if they will let you "play with their stick" to get a feel for it.
Old 11-28-2007, 07:40 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If your going to drive it like a Gorilla you will wanted the Pro 5.0, with the stops set properly it will not allow you to over shift. DO NOT get the short stick, it will create a leverage issue and you WILL have trouble with the 2-3 shift.
We just got dont solving that issue with a rebuilt t-56 and then it was swapped to a SixSpeedsInc m12 GTO trans, turns out the short stick was the issue.
Old 11-28-2007, 08:13 AM
02Z28LS1's Avatar
weird....i don't seem to have ever had a problem beating the **** out of my shifter with the short stick on it.....i've never missed/botched the 2/3 shift when powershifting since putting in the new shifter......
Old 11-28-2007, 08:43 AM
Internet Mechanic
Normally I would agree but ive seen it 1st hand. So take the advice for what you will.
Old 11-28-2007, 05:00 PM
I took my short stick off my 5.0 because my MBA shift **** would hit the console in 2nd gear since it was so low. It was fine with the original Hurst **** though if you like that. I cut little over an inch off the normal 5.0 stick and but my MBA **** on it and I think it's perfect.
Old 11-28-2007, 05:06 PM
lastcall190's Avatar
Had the Billet Plus on my LT1 and the Pro 5.0 on my LS1. They are both great shifters, I like how the handle on the Billet was angled (apparently you can get one for a Pro 5.0, might have to look into that). Gotta say the 5.0 just feels a bit more effortless.
BTW stock Hurst is NOT like the aftermarket Hurst shifter at all.
-J
