LS1 head/351W block???
Old 11-29-2007, 01:06 AM
jbk240z's Avatar
Question LS1 head/351W block???
Does this guy need to lay off the crack pipe or is this even remotely possible?
check this link....
http://forums.hybridz.org/showthread.php?t=127906
Yeah, I know........
Old 11-29-2007, 02:22 AM
classic gary's Avatar
and that's how you run a distributor on an LSx....................
Old 11-29-2007, 04:40 AM
HSV-GTS-300's Avatar
351W bore spacing = 4.380"
LS1 bore spacing = 4.400"
********GAME OVER***********
Old 11-29-2007, 10:04 AM
tirefryin_s10's Avatar
The swap has been succesfully completed numerous time's now . Requires a custom camshaft some small work to the head's a custom intake etc but it IS possible!
Old 11-29-2007, 10:17 AM
abot316's Avatar
Pics!!!!!!!!
Old 11-29-2007, 10:25 AM
search the net enough you will find pics
Old 11-29-2007, 10:58 AM
LS1GMCTruck's Avatar
Would a over-bore cure this?
Old 11-29-2007, 11:09 AM
Frank02L's Avatar
No, over bore would be within the bore spacing dimensions.
Old 11-29-2007, 11:22 AM
Jordan S.'s Avatar
He still needs to lay off the pipe a little haha
Old 11-29-2007, 02:41 PM
LSXS10's Avatar
I want to know more abouy this , by lookin at both headgaskets its kinda close... Scarey isnt it?????
Old 11-29-2007, 03:23 PM
Default Windsor W/LS1 Heads
I know people want to do this because they are Ford lovers & simply are looking for ways to improve their Windsor motors performance, and their Ford block is still bolted up to their tranny & all that, but... isn't there Ford heads(Cleveland) that bolt up without any intake, etc., hassles? The Cleveland heads were excellent flowing heads. They are available as aftermarket aluminum pieces as well.
Old 11-29-2007, 03:32 PM
Frank02L's Avatar
Yes, but if you can get a set of heads (L92s) that flow 325cfm as cast from GM for $350 (bare), thats $1000-1200 cheaper than aftermarket ford heads would cost. Yes Cleveland heads potentially flow more but they don't have any port velocity either. This would only apply IF you were an innovator and DIY'er with the proper equipment. Obviously the fab work could quickly exceed the savings on the heads.
Old 11-30-2007, 07:19 PM
jay_lt4's Avatar
i didnt find any,, you have any links to some pics of this swap?
Old 11-30-2007, 08:00 PM
chevycamaro350tpi's Avatar
Default 1
I found this http://460ford.com/viewtopic.php?p=138256
Old 12-01-2007, 11:31 PM
NemeSS's Avatar
Originally Posted by chevycamaro350tpi
alot of misinformation in that thread,
meh!
i dont care
Old 12-02-2007, 08:38 AM
Cam72aro's Avatar
But 700 bucks for a cam. That kills the idea of this being cheap.
Old 07-27-2008, 11:58 PM
seawalkersee's Avatar
Not really. If you think about it, a set of as cast GM heads for cheap and you already have the Ford stuff. Now...lets say even $200 dollars for the heads. You can not get an updated set for under $700 unless you know someone. I would say it is a wash but the GM heads have the cool factor. Can not wait to see someone bump that thread overthere.
Chris
Old 07-28-2008, 12:11 AM
lt4malibu's Avatar
this isnt the first time ive heard of this, anyhting is possible
Old 07-28-2008, 12:28 AM
zigroid's Avatar
why can't you go the other way around, ford heads on an LS1 block? so you can use their awesome canted valve heads or whatever heads kept winning the engine masters contest.
Old 07-28-2008, 08:59 AM
Those are CHI heads that make the car a "Clevor" which is a windsor lower with Clevland upper. I like the idea of the chevy heads on the Ford block for several reasons. Mainly because I have seen more than a handfull of LS1s with oiling problems in the mains. Not sure why either but they had a few knocks in the lower end. Second, I can use my own stuff on them to make it work.
Chris
Quick Reply: LS1 head/351W block???
