Spool and posi identification
Old 11-29-2007, 04:16 AM
Z06PSI's Avatar
Default Spool and posi identification
Rear end is out of the car.
Spool = both sides turning the same direction?
Posi = One side one way and the other the opposite direction?
Old 11-30-2007, 11:10 AM
Z06PSI's Avatar
Somebody?
Old 11-30-2007, 11:52 AM
ABA383's Avatar
Both the spool and posi (limited slip) will turn both wheels in the same direction...You'll have to pull the cover and see whats inside if its out of the car...
--Alan
Old 03-18-2008, 11:18 PM
MuscleCarZ28's Avatar
whats a spool?
Old 03-19-2008, 06:57 AM
BIG_MIKE2005's Avatar
A spool is just a piece that solidly connects the two axles together & bolts the ring gear to it. Both wheels always turn the same speed all the time like one solid piece.
A posi lets the inside tire turn at a different speed when cornering hard or just normal turning.
Old 03-19-2008, 11:30 AM
oh ok, thanks for educating me
Old 03-20-2008, 05:37 PM
99FormulaM6's Avatar
Just so you have an idea...
This is a posi:
This is a spool:
Old 03-20-2008, 06:24 PM
thanks for the pics
