Corvette Performance - looking for a good clutch set-up.
BONESTOCKC5
06-23-2003, 10:39 AM
Mcleod, cartek, or spec stage 4. for 427 C5. any body had good luck with any clutch setups?
Ling_650vette
06-23-2003, 06:20 PM
Heard good things about McLeod and SPEC. Theres another ive heard good things about, but cant seem to remember the company.
JoeyGC5
06-24-2003, 07:40 AM
What clutch does Ligenfelter use for the 550 and 650TT's?
DG Gordon
06-24-2003, 03:21 PM
I have the Ram 980 and it is supposed to be pretty good. It is stiff and grabby. It is holding on my 415 rwhp C-5
Ling_650vette
06-24-2003, 07:08 PM
Lingenfelter Clutch (http://www.lingenfelter.com/lingenfelter/product.asp?dept%5Fid=101&pf%5Fid=502) Here's what they sell anyway, and say thats what they typically install into their cars.
CorvetteMajor
06-25-2003, 07:56 AM
My buddy is using a Mcleod on a C-5 that runs 10.0 with no problem.
J-Rod
06-27-2003, 10:39 AM
McLeod dual disc is the top ticket as far as I know...
C_Williams
06-30-2003, 03:07 AM
Lingenfelter is way pricey...anyone have good results with the RAM on a 427? The Spec I have rattles like a tin can and eventually it either shuts up or I buy something else.
BTW, the SPEC is a solid unit and it really hooks, just noisy. And, it's only fair to add, with having the ability to put this much torque to the ground there are certain trade offs and compromises. I just want it all!
BergerMan
07-09-2003, 09:26 PM
Check out the CenterForce Dual Friction Clutch. I have this clutch in my Camaro and it is smooth as glass. It is rated for ultra-high hp cars. Summit has them for $384 + $82 for the throwout bearing.
Flyin'Brian
07-10-2003, 12:33 PM
RAM w/910 disk...no probs so far.
No chatter and it grabs w/ET streets :nod:
boweryboy
07-10-2003, 01:47 PM
I have a pretty radical engine set up (Vette Doctors 422) and the McLeod Dual Disk set up actually works great. I have a special Kevlar disc config and custom pressure plate with an aluminum flywheel. I have run several 9 sec runs and dozens on mid to low 10 sec runs and it has not slipped once. Knock on Wood ;)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
