Can MAP Numbers Help Detemine if there is a Vacuum Leak?
Old 06-23-2003, 12:09 PM
IRVINEWS6's Avatar
Default Can MAP Numbers Help Detemine if there is a Vacuum Leak?
Can MAP help determine if there is a vacuum leak. If so what numbers are signs of vacuum leak?
'00 WS6 M6
MTI Stage II heads, milled .030", B1 cam (220/220 114), LT's, Y-Pipe, free flow cats, Borla, Underpulley, Whisper lid, and Moser.
Old 06-23-2003, 09:39 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Default Re: Can MAP Numbers Help Detemine if there is a Vacuum Leak?
Yes it can be, although it would be better to tell on a stock cammed car, you would have to know what the MAP reading would be normally at idle to compare. The last one I seen that had a vacuum leak had about a 2v reading when the crack in the intake would expand.
Old 06-24-2003, 03:02 PM
eallanboggs's Avatar
Your MAP drop would be proportional to the size of the leak. You should run lean due to added air. Did you pull heads or intake? Check your work. Did you log data with AutoTap before AND after the SUSPECTED leak? Do you see a demonstrable difference in the MAP values at various load levels?
