Profesional Products 85MM Polished Intake Install
I am going to be installing this tomorrow along with the 85MM polished throttle body. I have read a lot of mixed reviews on this intake. I hope it works out well for me though.
Anyone have any advice on installing it other than the usual intake advice?
I will post pictures tomorrow after the install if it goes well!
I installed with without moving any of the coolant lines. It seams to have seated well. I will find out tomorrow when I fire it up! All I have left to do is put on the throttle body and hook up a few connections.
I will post pics of the install and the finished product tomorrow.
I also had no issue with the coolant line when I did my install. I hope that when you set the intake down you didn't slid it around. I made this mistake and it pulled the gasket over the number 7 and 8 intake runners a little.
Well, my brother and I finished the intake, fuel rail, and throttle body install this morning. We have about 4.5 hour into it. We took it really slow since there was not a lot written about installing this intake.
Over all the install went really smooth. I did NOT have to remove my stock 2000 LS1 coolant lines. Everything fit great. Here are some pictures during the install and when it was finished. I need to re-polish the intake and throttle body again though. If you have any questions feel free to ask.
Here is the engine bay before we started.
Engine bay with everything removed.
My brothers skinny *** in the engine bay. He is doing some cleaning.
The intake beginning to get installed.
The intake, fuel rails, and throttle body all installed.
I am having a Patrick G custom cam installed by EPP in the beginning of January so I will have some dyno numbers to show you guys with this combo.
