Most free flowing muffler
Old 11-30-2007, 11:14 PM
m6ttop's Avatar
Default Most free flowing muffler
lookin for a 3" inlet dual 2.5" outlet. sound is not an issue.I want the most power. any suggestions? dynos?
Old 12-01-2007, 04:48 AM
camaroguy26's Avatar
corsa is great. someone on here had his car dynoed with the corsa then through a cutout, and if I remember right the cutout only made 2 or 3 more horses then through the corsa.
Old 12-01-2007, 05:54 AM
BigKap94z's Avatar
Hooker aerochamber. I have that catback, made 419rwhp 387ft lbs tq through the muffler....and 421rwhp 389rwtq through a cutout. It would say it appears that it flows pretty well. I have a dyno graph showing that as well.
Old 12-01-2007, 12:09 PM
Steve Gunn's Avatar
I lost 1 rwhp through a Hooker vs. open cutout on a dyno.
Old 12-01-2007, 12:37 PM
Jeremiah's Avatar
My 570 Rwhp SS gained 1 rwhp and lost 4rwtq with a 3" open cut out over the Hooker cat back. In other words I lost power with the cut out wide open Vs. The closed Hooker cat back.
Old 12-01-2007, 12:47 PM
Pntbll309's Avatar
Man I didnt think the hookers were that popular!
Old 12-01-2007, 12:49 PM
1320 killer's Avatar
go with a true dual set up you'll make more power and they sound better.
Old 12-01-2007, 02:32 PM
silverLSWON's Avatar
slp d/d flows pretty good but is very quite
Old 12-01-2007, 02:43 PM
rocksws6's Avatar
Magnaflow for the win.
Old 12-01-2007, 04:07 PM
m6ttop's Avatar
can u buy the muffler alone(how much) or does it have to be the whole catback?
Old 12-01-2007, 05:31 PM
2000Hawk's Avatar
Dynomax Bullet, or just no muffler at all.
-Joel
Old 12-01-2007, 05:47 PM
litle88's Avatar
+1 for Magnaflow!
Old 12-01-2007, 11:27 PM
Jeremiah's Avatar
Wrong,
I know a few that have 400+rwhp cars and tried TD's and lost not only torque but also power, bigger isnt allways better. Trial and error is the only way to find out what works best for your combo. If your running a stock cube motor with a small cam and bolt ons I would stick with the traditional style set up. Although you cant beat the sound of true duals it may not be the best performer your set up.
Some cars do benifit from true duals... my car picked up just under 50 Rwhp but im also running a lot more cubes and moving a lot more air than those guys were.
Old 12-02-2007, 01:14 AM
Tech Resident
ChocoTaco369's Avatar
^^^Ummm...did they have a crossover? How about mandrel bends? If they just ran straight pipes off the headers, it's going to hurt them.
A 2.5" TD system with an X-pipe CANNOT be outperformed by an equally well-made y-pipe setup. It's completely impossible. A y-pipe simply cannot provide the scavenging an X-pipe can. You also don't want to go more than 2.5" on most setups for the LS1 because it'll sacrifice too much low end. A 400rwhp will perform much better overall with a 2.5" TD system, ESPECIALLY on the street. A 3" TD system will kill low end power. Go H-pipe for even more low end at the sacrifice of a few peak horsepower.
Your friends may have just had too big of exhaust piping for their applications or had a very poorly made crossover/no crossover at all.
Old 12-02-2007, 03:31 AM
miamifan3413's Avatar
Magnaflow period
Old 12-02-2007, 10:21 AM
omcar's Avatar
Magnaflow is a straight thru design and sounds good at wide open throttle. How can the Hooker be better?
Old 12-02-2007, 10:30 AM
mikenews's Avatar
+1 for the Magnaflow!
Old 12-02-2007, 10:41 AM
Jeremiah's Avatar
I think you guys read to many magazines,
I agree though on the pipe sizing as a genneral rule of thumb. Like I said before, every car/combo will react differently to different mods. Some combos run better with a little back pressure and smaller pipe where others seem to like a free flowing race style set up. It also depends on the usage of the vehicle.
The X pipe isnt allways the better option than the H pipe ither. you need high flowing race style system in order for the scavenging affect to work. If your running a full length system with restrictive mufflers then your X pipe is nothing more than an expensive balance cross over. Some real world evaluation has also shown the H pipe to make better average power than the X in some cases..... its all trial and error.
Old 12-02-2007, 10:55 AM
Jeremiah's Avatar
Just get the muffler and spend the money you saved on other mods. You wont see enough if any gains to justify the extra expense of a complete system with your set up.
Old 12-02-2007, 11:05 AM
jeffbab's Avatar
There's one guy on here that had much better luck with the Bassani true dual system than the catback he was using. (Borla I think?)
I think he gained 15 peak horsepower at the wheels.
That is the setup I will be going to next year.
Quick Reply: Most free flowing muffler
