WTB Stock Fbody LS1 Parts
I need as many stock engine parts that came with 99-02 F-body LS1 cars. I've bought a long block and need to start gathering up the parts needed to get the motor running.
Thanks For Your Help:
AJ
AJ
I have a A/C compressor, intake with throttle body, injectors, fuel rails, oil pan and all that needs to go with it.
I tore down a 99. Let me know what you need and I'll get a package together.
i have the following items off a 99 ta with 88,000 miles ran fine we did upgrades cam lifters h balancer stock or upgraded converter like new plug wires w/sleeve's intake air box front gears and chain and o2 sensor have pics of most items listed in dallas do ship daily do take paypal send me a email if you want pics mrmgtr@aol.com thanks
Ive got a '98 of mine that I went through and replaced quite a few things, along with a '99 and a '00 motor. I have almost every part to bolt together a factory motor. send me a pm if ya have anything in particular you are looking for.
Nine-Eight
Nine-Eight
Restricted User
I have alot of the hard things to find like. Here is what i got, shoot me an offer for what you want.
Motor mounts in great shape
knock sensors with harness
crank sensor
cam sensor
oil pressure sending unit
coolant temp sensor
all sensors include bolts and gaskets
valve covers with gaskets and bolts
front, rear, and valley covers with all bolts and gaskets
Tim
crank sensor
cam sensor
coolant temp sensor
Tim
From a 2002 Camaro SS A4
New Flex Plate (UpGraded Style)
Stock Injectors
Crank Pulley
Stock Manifolds, CATS, SLP Y-Pipe
Factory K-Member and Lower A-Arms, Torque Arm, & Pan Hard Rod
243 Heads with Upgraded Valve Springs and Titanium Retainers
Probably a bunch of other stuff in boxes.
Let me know if you need anything in particular
Stock Injectors
Crank Pulley
We have one set of LS1 engine heads, BRAND NEW never used from a 2004 engine.
one cam for 2004 LS! engine with timing chain and gear-never used
One intake manifold for LS1 engine with throttle body..All reasonably priced.
mojo melcher_8@hotmail.com
